Old 03-06-2008, 10:09 PM
Winterpark SSP's Avatar
Alibi
Exclamation 1993 Winterpark FL SSP
Guys,
It is official, The Winterpark SSP is 100% complete!!! I will upload more pictures as soon as it gets nicer here, attatched is one in my garage.
(I am not sure why I could not start this thread in the Aero Car Section)
I wanted to thank everyone that has helped me over this past 6 months.
I have not had the courage to tally up the receipts but am quite confident it far exceeds the value and I don't care. I don't ever plan on selling it and did it 100% correct.
Here is the final list:
[center]1993 Winterpark Florida SSP (72K Miles)
Restoration List[center]
• Synthetic Oil Change
• Rear End Fluid Change
• Brake Fluid Flush
• Power Steering Fluid Flush
• Antifreeze Flush
• 134A A/C Charge
• Spark Plugs/PCV Valve/ Air Filter/Spark Plug Wires/Fuel Filter
• Distributor Cap and Rotor
• Oxygen Sensor(s)
• Serpentine Belt
• Stabilizer Bar Links
• Steering Rack Boot(s)
• Coolant Overflow Bottle
• 130 amp alternator
• Rear Shocks
• Factory H-Pipe
• All vacuum hoses including vacuum harness
• Valve Cover, Plenum and Throttle Body gasket(s)
• 4 Wheel Alignment and Wheel Balancing
Engine Bay: (100 + Hours)
• New Air Box and Fender Studs
• Polished 5.0 Plenum Plate
• Oil Cap
• Power Steering Cap
• Radiator Cap
• Hood Stops
• Powder Coating:
o Valve Covers; Plenum; Throttle Body; Mass Air Flow Sensor; A/C Compressor Bracket; Power Steering Pump; Smog Pump; Charcoal Canister; Hood Latch, Radiator, Transmission Cooler and Pulleys.
o Cleaning: Underside of hood, all nuts/bolts, sheet metal, firewall etc.
Undercarriage: (60 Hours)
• Cleaning:
o Undercarriage covered in high strength all purpose cleaner and pressure washed with hot water to remove all dirt and debris.
o Wheels removed and cleaned and polished inside and out.
o All suspension parts sanded and coated with “POR 15” to original factory specs.
o Calipers/Brake Drums/Brake Lines Painted
o Driveshaft sanded and coated with” POR15”.
o Sway bars removed and powder coated.
o Exhaust wet sanded with 600 and 2000 grit sandpaper and polished to new finish.
o There is not a spec of dirt or grease on the undercarriage. Everything polished and highly detailed.
Exterior:
• Wet Sand entire car with 2000 grit paper
• Compound then Glaze with high speed buffer to mirror finish
• “Dent Wizard” (Paintless Dent Removal) removed all door dings, etc.
• Apply original “Winterpark Police” decals and stripes
• Front and Rear bumper covers removed from vehicle and painted
• Body side moldings removed and painted
• Roof holes patched and roof painted.
• New “Ford” front bumper cover emblem
• New Cowl Grill
• New Centercap(s)
• 5.0 Interceptor and “LX” trunk emblems
• OEM Headlamps/Marker Lamps/Parking Lamps
• Satin Black Powder Coated 10-Hole Rims (including spare)
Interior:
• Brake Pedal
• Factory OEM Floor Mats
• Interior Carpet
• Trunk Carpet
• Interior Floor Console
• Speakers
• Shifter Trim Plate
• Door Map Pockets
• Front Seats-reupholstered
• Window Tint
Electronics:
• Lenses for “SHO-Me” rear deck strobes
• Whelen 75W Strobe Power Pack (upgraded from 25 watt)
• Whelen “Hide Away Strobes” in taillights and side marker lights.
• Whelen “Dash King” windshield mount dual strobe.
• New Federal Signal PA300 Siren (upgrade from PA200)
• Motorola Spectra UHF Mobile Radio and Speaker
• Galls Headlight (Wig-Wag) Flasher/3x per second
• 4” 800mghz Trunk Antenna
• Federal Signal “JetStrobe” Lightbar (10 strobes/alley lights/takedowns)
• Custom bracket fabricated for Lightbar Controller replacing cassette pocket below radio.
• Custom shelf for trunk mounted radio base and strobe power pack(s).
Miscellaneous
• California Black Custom Car Cover (will fit light bar and spotlight)
Performance
(Wanted to keep factory with hidden/tasteful performance mod’s that can be turned back to original)
• B&M Transmission Shift Kit
• Ford Racing Headers (non-ceramic to look exactly like factory)
• 3.55 rear gears (Installed by Winterpark PD)
Collectables
• 1993 Ford ABS Police VHS Tape
• 1:18 Scale Mustang New York State SSP
• 1993 Ford Mustang Brochure
• 1993 Ford Mustang Police Interceptor Brochure
• 1993 SSP Supplement
• 1993 Ford Mustang SSP Order Form
• 1993 Ford Crown Victoria Police Interceptor Brochure
• 1993 Ford Taurus Police Interceptor Brochure
Barry
"Future Is What Present Does"
Collectables:
Other(s):
1995 Corvette ZR1 (859 miles)
"Kiddie Carrier"
Old 03-06-2008, 10:13 PM
WOW !! It looks great and much better than the brochure car.
Old 03-06-2008, 10:16 PM
BEAUTIFUL!!!
Old 03-06-2008, 10:17 PM
predator20's Avatar
A million times better than the brochure car.
Brian
1986 FHP 1742
1986 WSP 2761
Old 03-06-2008, 10:18 PM
Alibi
Thanks for the kudos guys!
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 03-06-2008, 10:25 PM
mustangretriever's Avatar
mustangretriever mustangretriever is offline
That's really nice! Do you have any in-service pics of it?
Eric
1989 Missouri State Highway Patrol SSP Mustang - P294
www.fotki.com/mustangretriever
Old 03-06-2008, 10:31 PM
Alibi
I have one from the officer who drove the car. It is sitting in his driveway at his home. I will scan it and upload it soon. I have been in close contact with him. The whole Winterpark PD department is excited to see the final product. It looks exact except for the black 10-holes.
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 03-06-2008, 10:35 PM
Mustang Crazy's Avatar
Mustang Crazy Mustang Crazy is offline
Looks Good!!!
'89 FHP Unit #1623
'89 FHP Unit #Unknown
'91 FHP Unit #1395
'93 FHP Unit #1660
'91 GSP Unit #1245
Old 03-06-2008, 10:46 PM
Very sharp and +1000 on the brochure car comments. Great job!
Old 03-06-2008, 10:54 PM
SparkSVT SparkSVT is offline
really nice job on that one. The only thing I would get rid of is the 5.0/police interceptor emblems for regular 5.0 emblems. That car does look great though.
