Old 01-02-2015, 12:17 PM
Jsteiner44 Jsteiner44 is offline
Default Gauge/Dash Light Will Not Turn Off
Hello All,
I'm recent owner of a 92 CHP SSP and new to the site. Although I have owned fox mustangs before I have never a owned a SSP. Over the past few weeks I have been going through the car and have come across few things that has me wondering if the subtle differences are because its a SSP or if something is wrong.
The one thing I have not been able to figure out is that gauge/dash light is always on, even when the headlights are not. The dimmer switch does not adjust the brightness but does turn on/off the dome light. In SSP cars is the dash light always on? If not has, anyone had similar problem with the dash light?
Thanks in advance.
Old 01-02-2015, 06:56 PM
Definitely something wrong there. Have you checked your headlight switch?
Old 01-03-2015, 02:14 AM
Could be the dimmer switch. Mine does the opposite. I try to adjust the dimmer wheel to keep the dash lights on, ( when headlights are on ) but it turns off.
It's a fine line on the adjustment to keep it on when headlights are on.
Dash lights are never on when headlights are off.
I replaced the switch with a newer used one, it was worse.
I am going to purchase a new dimmer switch to solve the issue.
Mike could be right as well, might also be the headlight switch.
Good luck.
Old 01-03-2015, 07:55 AM
damon23 damon23 is offline
The ignition switch in these fox's go bad and cause all kinds of weird unexplained issues. Although I've never experienced the issue you are having I would not rule it out.
Old 01-05-2015, 02:18 PM
Thanks!! Ill take a look at those items and we will let you know what I find out.
