Old 06-23-2014, 07:00 PM
FBI SSP's Avatar
FBI SSP FBI SSP is offline
Default 1991 Mustang Georgia SSP notchback - $10500 (Middletown)-OHIO
http://cincinnati.craigslist.org/cto/4535150163.html
91 mustang SSP rust free body with BBK sub frame connectors
Motor
302 flat top pistons ,B303 cam,GT40p heads and Intake ,65 mm throttlebody,1.7 roller rockers,C&L cold air intake , polished underdrive pulleys, polished ceramic coated headers
Drive train
World-class T5 , Ford motorsport cobra clutch , Ford motorsport adjustable cable, clutch quadrant and firewall adjuster ,Steeda tri-ax shifter,Ford Motorsport aluminum driveshaft, Lakewood drive shaft safety loop
Suspension
Front
AJE K member and A arms , flaming River quick ratio manual rack kit , strange 10 way adjustable struts with coil overs, 94 spindale and breaks with drilled and slotted rotors , 94 power brake booster
Rear
8.8 ford Motorsport 3.73 gear , axels tubs welded ,URP girdle , comp engineering 3-way adjustable shocks , URP single adjustable lower control arms ,Steeda double adjustable upper control arms ,1.5 Lower springs ,94 breaks drilled and slotted rotors , Northing race car axle Kit to move the brakes back in the stock , Yukon Harding axles
Interior
Sport interior with Automator gauges and A/C all hooked up and works with R34A
Call (513)320-2834 $10500 obo or Trade
1993 FBI SSP
Old 06-25-2014, 05:17 PM
non airbag wheel not correct for 91...
Did anyone get the vin for the VIN Project?
