Old 03-11-2014, 09:19 AM
Default 1988 possible SSP in Indiana
http://indianapolis.craigslist.org/cto/4368034401.html
1988 Mustang Notch 5.0 - $2700 (Mitchell IN)
I have a 1988 mustang notch 5.0 5 speed car. Its not a 4cyl car swapped to a v8. It needs quite a bit of work. Im in the process of putting new struts and shocks on it. Also putting caster/camber plates on it and getting it aligned this week. heres whats up with it:
Good- It has a new clutch, adjustable clutch cable, clutch quadrant (needs put on), new 3.73 gears, MAC headers, flowmaster exhaust (needs tips which I have put on because its pretty loud), brand new tires with maybe 15 miles on them (turbine rims), and new front rotors.
Bad- needs a LOT of body work and paint. I have another front nose piece for it and a driver side fender. Has a 4 inch cowl hood that is a full pin on (I hate), and it needs the rubber grommet for the fuel filler neck because it leaks.
She needs an owner that can give her the attention it needs. Its a project car. I think it has a vacuum leak as well. I have taken the upper intake off and put new intake gasket, throttle body gasket, and IAC valve gasket on it. Its got new plugs and wires, new cap and rotor, and an aftermarket coil. Still bogs at first when you rack it off. Also it may be a SSP car but not for sure. I dont have any pictures of inerior. It needs more help then the outside. I have everything there except the back seat. The pictures you see is all I have. Can get more on friday 15th. It would have to be on a weekend when I could get rid of it do to living in columbus and the car being it mitchell. But you can go look at it anytime before 2:30 mon-fri.
I am willing to take 2700 obo or possible trade for 89-95 mustang, maverick, comet, older ford, mopar, and gm cars. NO 4 WHEELERS, boats, rangers, or anything like that. If you think I'd be interested in what you have, let me know.
The seller may get back to me with add'l photos, but he said the VIN ends with JF247133, which is not in a grouping of 3 or more VINs.
Old 03-11-2014, 09:45 AM
Bill,
we confirmed that car as a 88 GSP a while back.
Old 03-11-2014, 09:49 AM
He sent a door sticker and I forwarded to you can not remember which vin though?
http://www.specialservicemustang.net...ead.php?t=5105
Old 03-11-2014, 09:52 AM
It looks like a GSP, doesn't it? The VIN is JF247133 according to the seller. I will check to see if the photo you sent me is sitting in a folder somewhere. Can you check your GSP records for this VIN?
Old 03-11-2014, 09:59 AM
If that vins correct then it is not a GSP 225718-225817 are the 100 GSP's
Old 03-11-2014, 10:05 AM
Maybe I got confused and that is the one that would never send info? But I do remember that car and it having the black passengers fender... And it being implied it was a GSP
Old 03-11-2014, 10:43 AM
Thanks for checking, Bobby!
Old 03-11-2014, 10:49 AM
I was fixing to see about buying it
Old 03-11-2014, 11:19 AM
JF247133 is a single VIN
Original state that it shipped to is unknown but the first registration event was from 1998 in IL.
Old 03-11-2014, 12:39 PM
Thanks Mick. I will post up if the seller provides any more information.
