Old 10-16-2013, 09:21 AM
rick978 rick978 is offline
Father and Son
Default 1985 SSP carb gasket/heat shield gaskets ?
i have the carb and heat shield is there a spacer too or just 2 gaskets ? and where do i find the correct gaskets my local parts store only lists a four hole one for the heat shield there not sure if i need two of the same or if there is 2 different ones any help is appreciated thanks rick r
Old 10-16-2013, 10:39 AM
There is also an EGR spacer below the heat shield. So there should be three gaskets...
carburetor
---gasket---
heat shield
---gasket---
EGR spacer
---gasket---
intake manifold
If I remember correctly the gasket between the heat shield and the EGR spacer was thicker than just a paper type gasket. And the gasket between the EGR spacer and intake manifold has to have a slot (for EGR gasses) in the rear passenger corner in addition to the four Venturi holes.
Old 10-16-2013, 10:48 AM
Father and Son
thanks will have to look into the egr plate
