Old 11-01-2011, 08:20 PM
bob macdonald bob macdonald is offline
Default Headlamps
My 93 SSP has XENON 35w High Tech Light bulbs. I want to go back to stock so I can put wig wags in. Is it simply the removal of the Electronic control box, per light, and replacing them with stock? Any help would be appreciated.
Old 11-01-2011, 08:49 PM
Just undo te ring at the back of the headlight assembly (plastic housing, the ring twists, then pull back). Then you just pull out the bulb and unplug the wire plug.
This is what a factory bulb looks like
Headlight ring behind headlight
Old 11-02-2011, 11:31 PM
Default Headlamps
Thanks Sam Appreciate the help. I'll let you know how I make out.
