Old 07-27-2011, 11:21 PM
sspanthony's Avatar
sspanthony sspanthony is offline
Mustangoholic
Default A/C & Heat all going thru Defrosters
Recently had to replace my heater control because the indicator switch would not switch from panel, floor, mix, etc.... Every setting would cause the air to flow through the defroster at the top of the dash as a default.
I replaced the complete heater control unit and now it switches correctly as it should "BUT" everything is still coming thru the defroster ??? I checked for vacuum leaks but didn't see any apparent issues?
Anyone ever run into this ??
93 SCHP
92 FHP
MCA Member
Old 07-28-2011, 07:20 AM
Very tiny black plastic vacuum line running across the top of the firewall. That feeds the climate control assembly. Check that line for vertical breaks or horizontal splits. That's the most common place for a vacuum leak. There are other places of course.
Here is a diagram of the HVAC vacuum controls, courtesy of TMoss (Tom Moss) and veryuseful.com:
http://www.veryuseful.com/mustang/te...m_controls.gif
Old 07-28-2011, 07:29 AM
1988Bullitt's Avatar
1988Bullitt 1988Bullitt is offline
Has to be a vacuum leak somewhere, default position with no vacuum is defrost. The vacuum line mentioned above is a good starting point as it is the main vacuum line to your HVAC system.
-Aaron
1992 SSP Kansas Highway Patrol #264 Troop H
1991 SSP Georgia State Patrol Perm/Trunk #1195, Roof/Badge/Tag #813
Old 07-28-2011, 08:02 AM
I have run into this. Behind the glove box is a series of vacume lines that intersect and connect in a "group" or "junction fitting" (for lack of better words). When I had that same exact problem it was because a line had pulled loose from this fitting. Once I plugged it in the problem was fixed.
