Go Back   Special Service Mustang.net Forums > Other Mustangs/Miscellaneous
Other Mustangs/Miscellaneous For sale/Wanted/Parts-non SSP
Old 03-23-2010, 10:19 PM
ABN2060's Avatar
ABN2060 ABN2060 is offline
Default 1993 GT (many mods)
I have been working on getting this car back to a respectable condition for the last 8 months or so. The previous owner was a hack and I pretty much fixed all his "work". The interior is a 8/9 out of a ten however the body will need paint but looks good at 20'. Carfax shows an accident in 2000 with damage to the pass front which was repaired nicely. The quarter window molding is in great condition with no signs of deterioration.
Everything listed has been bought new and installed within the last 6 months:
-Body has ~135K Miles/ Original Florida car
-Have the original window sticker
-Tuned by Tony Gonyon at Tuners Inc (formerly HP Performance) Custom chip burned ($350 alone)
-267 RWHP with little over 300 ft lbs torque/Dyno sheet available
-Stock bore 1988 5.0 shortblock with forged pistons
-OEM '93 Cobra upper/lower intake (ported)
-GT-40 heads (mildly ported)
-Trick Flow Stage 1 Cam
-Crane 'Cobra' 1.7 Roller Rockers
-Crane Cams double roller timing chain
-MSD coil
-MSD cap and rotor
-FRPP plug wires
-'94 Cobra Valve Covers
-Prothane motor and transmission mounts
-Ice cold A/C (R-134a conversion)
-Pro 5.0 shifter
-Newer T-5
-Strut tower brace (unknown make)
-New Melling Oil Pump
-All Felpro gaskets
-3G Alternator Upgrade
-70mm BBK TB
-C&L 73mm Mass Air
-K&N panel filter
-24lb injectors
-FRPP SS Headers
-BBK X-Pipe
-Flowmaster Force II Cat Back Exhaust
-Rear '88 Turbo Coupe disk brake conversion (MM PV Delete/ 3-2 conversion)
-'93 Cobra Master Cylinder
-Willwood Adjustable Proportioning Valve
-BBK 'Gripper" lower rear control arms
-FRPP upper rear control arms
-FRPP front lower control arms
-Wild Rides Lower Torque Boxe reinforcement (HP Performance)
-Tokico Blues
-FRPP 'C' Springs w/ isolators
-FRPP 3.73 gears installed by Hurricane Performance (HP Performance)
-FRPP Diff Cover
-FRPP Clutch quadrant
-Heavy Duty adjustable clutch cable
-Steeda full length subframe connectors
-Steeda Caster Camber plates
-New Opal Grey Carpet/ Floor Mats
-OEM LX Tail Lights
-Proliance OEM replacement radiator from Summit
-Mr Gasket 180* T-stat
-FRPP smog pump delete
-White face gauges
-JVC detachable face CD player
-Cruise control, panel gauges/lights, interior lights, fog lights, windshield wipers, trunk release and ash tray cover all in perfect working order.
-Located near Jacksonville, FL $6000 OBO
-email abn2060@yahoo.com or PM if interested
Old 03-23-2010, 10:20 PM
ABN2060's Avatar
Old 03-23-2010, 10:22 PM
ABN2060's Avatar
Old 03-23-2010, 10:23 PM
ABN2060's Avatar
Old 03-23-2010, 10:25 PM
ABN2060's Avatar
Old 03-23-2010, 10:26 PM
ABN2060's Avatar
Old 03-23-2010, 10:30 PM
ABN2060's Avatar
The carpet looks stained in the pictures but that is just some weird camera effect. I really hate to sell but this SSP bug got me. I'm real anal when I rebuild cars so this one is put together right.
Old 03-23-2010, 10:34 PM
Nice Car !! love that color ! some call it Electric Red ..correct ?
best of luck on the sale , i will tell the fellas at work.
since i started working for the company there are now 7 mustang guys , imagine that .
Old 03-23-2010, 10:40 PM
ABN2060's Avatar
OK Thanks.
It sounds and drives even better. Mods are tastfully done and I used OEM parts when I could. It lopes just enough to let everyone know somethings there but it idles very nicely.
Old 04-09-2010, 08:49 PM
ABN2060's Avatar
Price drop to $5500. Will consider a trade for another SSP....
