Old 05-06-2009, 02:02 PM
SSPGARY's Avatar
SSPGARY SSPGARY is offline
Default What Gears are You Running?
I can't live with the stock 2.73s so I'm going to upgrade to 3.55s. Anyone running this ratio?
Gary
2003 AB Mach 1
1992 PASP ( Sold )
2013 Focus ST
2008 P71
Old 05-06-2009, 02:26 PM
Unmrkd's Avatar
Unmrkd Unmrkd is offline
Resident Geezer
Talking
You will get many different opinions on this one. I have 3.55s in my '88 red SCHP 5-spd and really like them. They put the car in a range of performance and driveability ( haul but not over rev at sustained highway speeds) . If the car is an auto, you might want to consider 3.73s.
A lot depends on what you want it to do with it. IE: daily driver or howl the hides every time you leave the house (4.56s). Good luck with your decision.
Gregg
'89 FHP Unit # 435 (Deceased)
Old 05-06-2009, 04:37 PM
3:73's for me.
Old 05-06-2009, 04:47 PM
YellowMurci's Avatar
YellowMurci YellowMurci is offline
3:73 in my notch too!
Old 05-19-2009, 05:47 PM
86ColoradoSSP's Avatar
86ColoradoSSP 86ColoradoSSP is offline
I've ran both gears in my street Mustangs over the years and 3.73's are in my opinion, the way to go. You'll see around 2450 rpms @ 75mph on the highway with a 5 speed and 275-45-15 tires. If you have your heart set on going with 3.55's I have two new sets of Ford Motorsport gears for an 8.8that I will ship to you for $140. Please PM me if I can help you out...
Old 05-21-2009, 10:28 AM
copper's Avatar
copper copper is offline
Default 3.73 speedometer gear
I have a 3.73 in the WI SSP and the speedometer was way off when I drove it. I checked the gear at the end of the speedometer cable and it was a 21 tooth but some of the teeth were worn off which could count for the needle wondering. What did you guys do to get the speedometer close to accurate? I read that the trans drive gear in the 93s had 8 teeth and on the chart, it indicated I would need the max of 23 tooth gear on speedometer and it would still be a bit off. They also mentioned the nylon gears last a little while and then it may break some teeth like the one I have. The other choice was to change the trans drive gear to a 6 or 7 but it is a big job. Any help would be appreciated or will I have to just live with it. Thanks
Old 05-25-2009, 02:52 PM
FHP#1357's Avatar
FHP#1357 FHP#1357 is offline
Default 3:27
I have a 93' Cobra disc brake rear in mine it has limited slip and factory 3;27 gears, in the rain you can drift on demand and in the dry it will break'em loose at will
John Costa
1993 EX-FHP #1357
1991 NCHP #91-1212
2005 GT UNMARKED
www.photobucket.com/johnsrides
Old 05-25-2009, 03:37 PM
Gary
Gary, I HATE 2.73's.....in anything so I don't blame you. I have 3.27's (original gear ratio) in the 93 FHP with the auto trans and it runs alot better than the 2.73's. I also plan on putting 3.55's in the gray coupe to make it more fun to drive.
Old 10-15-2009, 01:09 PM
SSPCoupe SSPCoupe is offline
Thumbs up Gears
I'm running 430 Gears on my 1988 Mustang SSP!
Old 10-15-2009, 01:46 PM
Originally Posted by FHP#1357 View Post
I have a 93' Cobra disc brake rear in mine it has limited slip and factory 3.27 gears, in the rain you can drift on demand and in the dry it will break'em loose at will
I have this exact rear in my 85 (the original 7.5" rear is long gone). I like the 3.27's OK, but I am considering a gear change over the winter to 3.90's or 4.10's (keep in mind I have tall 255 BFG's out back). With the 3.90's and tall tires, my final effective gear ratio would be close to 3.73's, should I ever fix my speedo.
