Old 04-19-2009, 08:01 PM
Default Fuel Pump Help
Need a some suggestions on a what I think is a fuel related issue. It's a '92 5.0 w/95k miles. I took it out for a short drive, shut it off and an hour later it cranked and cranked and cranked, then started. Brought it home, shut it off and tried to start it back up and it just cranked but would not start. I am not hearing the fuel pump being primed when I turn the key, the starter just turns. Where would you recommend beginning? I have never had any fuel related issues so I am new to the issue and possible causes. Thanks.
Old 04-24-2009, 09:04 PM
Try checking the fuel pump relay. I believe it is under the drivers seat. If you bypass it and the pump works...there is your problem.
