Old 03-19-2009, 04:50 PM
TexasMade's Avatar
TexasMade TexasMade is offline
Default 1984 Testin waters: Ex DPS Mustang Coupe 5.0 5SPD
Coupe may have to go.
Here is the rundown.
1984 Coupe in very solid shape
body
is a 7.5 of 10(7.5 due to the hood coming up), it was somewhat fixed, but reveiled previous body work underneath. Paint is losing the clearcoat. Has a 21/2 fiberglass cowl hood. Has 2 bottles and battery box mounted in trunk.
Interior
Interior was sprayed black by previous owner looks decent, but has some bad parts. Has newer nice black seats from a 91, fast and furious steerin wheel. Gas gauge, tach, speedo, and factory oil pressure work. Has Mechanical 25/8s oil/water mounted above glovebox. Blaupunkt radio, A/C blows cold, ut only through the defrost, and floor. Shift light hidden in vent wih 5600 pill. back seat is the 91 lower with painted 84 upper. 6x9s in back dash with 51/4s in front lower kick panels.
Motor
91 Forged Bottom end mayb stock/maybe rebuilt carrys 40-50 psi warm running down the road, with the new 10w30 it has about 25psi at idle, but jumps up as soon as you touch the gas. GT40 heads not p's, with 1.94/1.60 valve ported to get casting flash out of runners, 1.460 springs good for .580 hyd roller, milled .010, and milled on int side to even it out, 1.6 proform?(I believe)rr's, Ed curtis custom ground Nitrous cam, Victor Jr., edlebrock 650, Duraspark dizzy all rebuilt 2 weeks ago with Chevy modue, new MSD blaster coil. 15/8s longtubes with O/R h with flows and tail pipes, holley red with full 3/8ths line, areomotive regulator with boost referance ability, NX quad Gemini 2 stage plate 50-800 HP capable, two full bottles, two feed lines. Kit is installed , but not wired yet. Car has Ls1 Camaro fan on a relay.
Drivetrain
Upr quick release quadrant, Brandnew stock cable, Spec stage 3+ clutch, Tremec TKO 500, <both have less than 4K on them, stock D/S, 8.8 with 3.08s, MM full length sub frames with seat braces, Lake wood adjustable lift bar lowers with none adjustable uppers, new autozone white shocks, stock springs. I have a complete 99 K member to do a 5 lug swap up front
Sitting on some 10 holes now.
Looking for $5000 obo. I have many other parts that go with car not yet installed. More pics and vids coming after I can move around better just came home from surgery.
93 Coupe-Eternal Project
84 TX DPS D.S.O. 57-0132 Vin-184626
Even fish could stay out of trouble, if they learn to keep their mouth's shut!
Old 02-14-2010, 04:14 AM
TexasMade
This message has been deleted by NoDrama43. Reason: read the forum rules please. Thanks.
