Old 03-07-2009, 10:19 AM
Default Courtesy Light
I would like my courtesy light to work. Where in my 1993 SSP is it desconnected? The map lights work.
Old 03-07-2009, 10:48 AM
Unmrkd's Avatar
Unmrkd Unmrkd is offline
Resident Geezer
Remove the trim "Kick" panels (under the dash) on both sides. There will be a small harness on each side with a round white plastic sheathe tucked or secured by tape to the structure. Reach inside the access hole area behind the courtesy switch to find it. Then the fun begins, trying to align the harness end with three small pins to the connector of the switch itself with three small recipticals .
It's not complicated but just tight quarters and you can't see the back of the switch, so it has to be accomplished by feel. That should do it, good luck.
Gregg
'89 FHP Unit # 435 (Deceased)
Old 03-07-2009, 10:53 AM
Thanks Gregg! I'll work on it this afternoon.
Old 03-07-2009, 05:54 PM
Smile Got Light!
I got my courtesy light to work now! Yeah! I started out trying to do it as you suggested. And as you said, it is very tight in there. So, I did it a different way. Which ended up to be much easier. I pulled the switch out of the A-pillar. Then I ran some wire down through the hole to fish the plug through. Retrieveing the wire, I taped the plug onto the end and pulled the plug back up through the hole. Made the connection to the switch. Put the switch back in the A-pillar. Took less than 3 minutes.
Old 03-07-2009, 06:31 PM
Unmrkd's Avatar
Resident Geezer
Good deal, glad you got it working.
Gregg
