Old 04-05-2008, 09:27 PM
Default Finally found....
Some nice door panels for the '83 TX car. '83 was a one-year only for this style of door panel, as the '82 panels were different and black was dropped by Ford for '84. Same goes for the Walnut ones on the '83 CSP car, but I actually found a spare set for the '83 CSP car awhile back, which has nice, original panels in it anyway. Walnut is much rarer than black, according to the production stats Stew Jones put out, so go figure. Anyhow, I was very lucky to find these.
Old 04-05-2008, 09:30 PM
predator20's Avatar
Good deal. Post up some pics of the '83 TX or e-mail them to me. I've only seen the front.
Brian
1986 FHP 1742
1986 WSP 2761
Old 04-05-2008, 09:42 PM
You aren't missing much....it's the roughest car I have.
Here is a rear shot...took these when I replaced the damaged steering column and broken ignition switch.
Old 04-05-2008, 09:44 PM
The rotted rear package tray(and rear seat)...you can see the holes where the PAR36 halogens were mounted.
Old 04-05-2008, 09:51 PM
One more...I had the dash torn apart and this was just before I pulled the column. It's now back together with the correct steering wheel in it (just so I can move it). You can also see how bad the drivers door panel is warped. It's was actually warped much worse than the pic shows. I saved it to transfer the shotgun rack mounting points over, but it's not currently in the car.
You can also see the holes TX drilled into the console delete for switches for the e-equipment.
The seat is a temp...that I will have recovered when I do the rest of them. The original had been tossed and replaced with a plastic racing seat.
Old 04-05-2008, 09:56 PM
predator20's Avatar
Dang that is rough. At least it's mostly there....somewhat.
Brian
1986 FHP 1742
1986 WSP 2761
Old 04-05-2008, 10:04 PM
Like I said...you weren't missing much.
I have an NOS decklid for it, a nice replacement hood, and there's no rust anywhere. I think that the hardest part (other than 5 layers of paint) to deal with will be finding/replacing all of the emissions/vacuum lines and misc. stuff I'm missing under the hood. Good thing is I have the CSP car to use as a guide. It's completely unmolested. That and it came with this:
Old 04-05-2008, 10:06 PM
predator20's Avatar
Yeah, you need to change your name to Mr. Buildsheet. Your FHP's didn't have them though right? Just the '82 and both '83's.
Brian
1986 FHP 1742
1986 WSP 2761
Old 04-05-2008, 10:11 PM
Correct...and the '92 I drove in-service (that I sold 2 years ago). I place blame on Jim Y. for the '85 (every car he touches that has one spontaneously eats the sheet).
I checked the '93 in the usual spots, but I haven't had the carpet out of the car yet. I basically cleaned it up and parked it after I bought it at the auction (after driving it a little).
Old 04-05-2008, 10:19 PM
predator20's Avatar
Yeah Jim must be cursed... as many ssp's he owns and not have one single buildsheet.
Brian
1986 FHP 1742
1986 WSP 2761
