Old 04-10-2008, 08:44 AM
Winterpark SSP's Avatar
Alibi
Talking Gunrack Picture
Nice addition to the SSP, purely for "effect".
Barry
"Future Is What Present Does"
Collectables:
Other(s):
1995 Corvette ZR1 (859 miles)
"Kiddie Carrier"
Old 04-15-2008, 09:05 PM
Alibi
Post "The FINAL LIST"
Wow, did I really do this much??? Still not enough courage to add up receipts
1993 Winterpark Florida SSP (72K Miles)
Agency: Winterpark Florida PD
Unit: 1017
DSO: 27-0409
Dealer: Don Reid Ford, Maitland FL 32751
•Synthetic Oil Change
•Rear End Fluid Change
•Brake Fluid Flush
•Power Steering Fluid Flush
•Antifreeze Flush
•134A A/C Charge
•Spark Plugs/PCV Valve/ Air Filter/Spark Plug Wires/Fuel Filter
•Distributor Cap and Rotor
•ICM (Ignition Control Module)
•Oxygen Sensor(s)
•Serpentine Belt
•Stabilizer Bar Links/Bushings
•Steering Rack Boot(s)
•Coolant Overflow Bottle
•130 amp alternator
•Rear Shocks
•Factory H-Pipe
•All vacuum hoses including vacuum harness
•Valve Cover, Plenum and Throttle Body gasket(s)
•4 Wheel Alignment and Wheel Balancing
Engine Bay: (100 + Labor Hours)
•New Air Box and Fender Studs
•Polished 5.0 Plenum Plate
•Oil Cap
•Power Steering Cap
•Radiator Cap
•Hood Stops
•Powder Coating:
Valve Covers; Plenum; Throttle Body; Mass Air Flow Sensor; A/C Compressor Bracket; Power Steering Pump; Smog Pump; Charcoal Canister; Hood Latch, Radiator, Transmission Cooler and Pulleys.
Cleaning: Underside of hood, all nuts/bolts, sheet metal, firewall etc.
Undercarriage: (60 Labor Hours)
•Cleaning:
Undercarriage covered in high strength all purpose cleaner and pressure washed with hot water to remove all dirt and debris.
Wheels removed and cleaned and polished inside and out.
All suspension parts sanded and coated with “POR 15” to original factory specs.
Calipers/Brake Drums/Brake Lines Painted
Driveshaft sanded and coated with” POR15”.
Sway bars removed and powder coated.
Exhaust wet sanded with 600 and 2000 grit sandpaper and polished to new finish.
There is not a spec of dirt or grease on the undercarriage. Everything polished and highly detailed.
Exterior:
•Wet Sand entire car with 2000 grit paper
•Compound then Glaze with high speed buffer to mirror finish
•“Dent Wizard” (Paintless Dent Removal) removed all door dings, etc.
•Apply original “Winterpark Police” decals and stripes. Manufactured by Graphic Imaging of Florida (original supplier).
•Front and Rear bumper covers removed from vehicle and painted
•Body side moldings painted back to body color
•Roof holes patched and roof painted.
•New “Ford” front bumper cover emblem
•New Cowl Grill
•New Centercap(s)
•5.0 Interceptor and “LX” trunk emblems
•OEM Headlamps/Marker Lamps/Parking Lamps
•Satin Black Powder Coated 10-Hole Rims (including spare)
Interior:
•Brake Pedal
•Factory OEM Floor Mats
•Interior Carpet
•Trunk Carpet
•Interior Floor Console
•Speakers
•Shifter Trim Plate
•Door Map Pockets
•Front Seats-reupholstered
•Package Tray (rear deck)
•Window Tint (lightest film, for contrast)
•“Big Sky” Trunk Mounted Shot-Gun Rack
Electronics:
•Whelen Dash Master Deck Strobes
•Whelen 75W Strobe Power Pack (upgraded from 25 watt)
•Whelen “Hide Away Strobes” in taillights and side marker lights.
•Whelen “Dash King” windshield mount dual strobe.
•New Federal Signal PA300 Siren (upgrade from PA200)
•Motorola Spectra UHF Mobile Radio and Speaker
•Galls Headlight (Wig-Wag) Flasher/3x per second
•4” 800mghz Trunk Antenna
•Federal Signal “JetStrobe” Lightbar (10 strobes/alley lights/takedowns)
•Custom bracket fabricated for Lightbar Controller replacing cassette pocket below radio.
•Custom shelf for trunk mounted radio base and strobe power pack(s).
Miscellaneous
•Factory Reproduction Window Sticker
•California Black Custom Car Cover (will fit light bar and spotlight)
Performance
(Wanted to keep factory with hidden/tasteful performance mod’s that can be turned back to original)
•B&M Transmission Shift Kit
•Ford Racing Headers (non-ceramic to look exactly like factory)
•3.55 rear gears (Installed by Winterpark PD)
Collectables
•1993 Ford ABS Police VHS Tape
•1:18 Scale Mustang New York State SSP
•1993 Ford Mustang Brochure
•1993 Ford Mustang Police Interceptor Brochure
•1993 SSP Supplement
•1993 Ford Mustang SSP Order Form
•1993 Ford Crown Victoria Police Interceptor Brochure
•1993 Ford Taurus Police Interceptor Brochure
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 04-15-2008, 10:25 PM
SparkSVT SparkSVT is offline
can i see pics of the undercarrige and motor area? thanks
Old 04-16-2008, 07:23 AM
Alibi
Default Photo Link
http://public.fotki.com/da35114/1993-mustang-ssp/
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 04-27-2008, 11:29 PM
5pt0Joe's Avatar
5pt0Joe 5pt0Joe is offline
'88 MA & '90 TX SSP's
Truly beautiful! Amazing job!
1990 Mustang SSP TX DPS
1988 Mustang SSP MA State Police
1990 Mustang 2.3L Notch
1989 Mustang GT 5.0 Hatch w/36K All Original
1989 Mustang GT Conv. RARE W/OUT FACTORY A/C
http://www.5pt0joe.com
Old 04-28-2008, 07:01 AM
Alibi
Thumbs up Thank You!
Thanks! My last "piece to the puzzle" was the replacement of the rear "package tray" (from FMR) and changing the Galls round strobes to Whelen Dashmiser(s) to match the front mirror mount dual red/blue Dashmiser.
I was only keeping the Galls (rounds) as I did not want ANOTHER set of holes in the old package tray installing the Whelen's. I will upload a picture soon
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 05-03-2008, 01:30 PM
Alibi
Default Rear Deck Light(s): Picture
Whelen (self contained) Dashmiser(s) to match the dual red/blue Dashmiser on windshield.
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 05-03-2008, 01:32 PM
Alibi
Default Newest Picture
Now that the lawns are green
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 05-03-2008, 02:42 PM
Again, the car looks amazing. Has the Winter Park PD shown much interest in seeing the finished product? Being such a small community, and PD I would think they would love to see it.
Old 05-03-2008, 03:51 PM
Alibi
Default Winterpark PD
Yes, they are "enthralled" by it. I just spoke today to the assistant chief, feet manager and patrolman who drove the vehicle. They are sending up a box of goodies consisting of hats, sweaters, t-shirts etc all with the Winterpark Police patch on them.
Nice "props" for future shows.
Barry
Collectables:
Other(s):
"Kiddie Carrier"
