Old 01-24-2008, 04:46 PM
Winterpark SSP's Avatar
Alibi
Talking Winterpark SSP-Pictures (Finally!)
I am not sure why I could not get the thread started for the "aero-cars", but heres the link:
http://public.fotki.com/da35114/1993-mustang-ssp/
I will add more as work is completed.
1993 Winterpark Florida SSP (72K Miles)
• Synthetic Oil Change
• Rear End Fluid Change
• Brake Fluid Flush
• Power Steering Fluid Flush
• Antifreeze Flush
• 134A A/C Charge
• Spark Plugs/PCV Valve/ Air Filter/Spark Plug Wires/Fuel Filter
• Distributor Cap and Rotor
• Oxygen Sensor(s)
• Serpentine Belt
• Stabilizer Bar Links
• Steering Rack Boot(s)
• Coolant Overflow Bottle
• 130 amp alternator
• Rear Shocks
• All vacuum hoses including vacuum harness
• Valve Cover, Plenum and Throttle Body gasket(s)
• 4 Wheel Alignment and Wheel Balancing
Replacement Parts
• Interior Carpet
• Trunk Carpet
• Shifter Trim Plate
• Bumper Cover Emblem (front)
• Interior Floor Console
• Speakers
• New Air Box and Fender Studs
• Factory OEM Floor Mats
• Polished 5.0 Plenum Plate
• 2 Factory Center caps
• Oil Cap
• Power Steering Cap
• Radiator Cap
• Brake Pedal
• Hood Stops
• 5.0 Emblems and “LX” trunk emblem
• OEM Headlamps/Marker Lamps/Parking Lamps
• New Lenses for Vector Light Bar
• Lenses for “Sho-Me” deck strobes
• New 75W Strobe Power Pack (upgraded from 25 watt)
• “Hide Away Strobes” in taillights and side marker lights.
• Powder Coated 10-Hole Rims
• New Federal Signal PA300 Siren (upgrade from PA200)
• Motorola Spectra UHF Mobile Radio and Speaker
• Galls Headlight Wig-Wag Flasher/3x per second (upgrade from basic 1x per second)
• 4” Trunk Antenna
Restoration (too much to list)
General highlights:
Engine Detail: (100 + Hours)
• Powder Coating:
o Valve Covers; Plenum; Throttle Body; Mass Air Flow Sensor; A/C Compressor 7 Bracket; Power Steering Pump; Smog Pump; Charcoal Canister; Hood Latch, Radiator, Transmission Cooler and Pulleys.
o Cleaning: Underside of hood, all nuts/bolts, sheet metal, firewall etc.
Undercarriage Detail: (60 Hours)
• Cleaning:
o Undercarriage covered in high strength all purpose cleaner and pressure washed with hot water to remove all dirt and debris.
o Wheels removed and cleaned and polished inside and out.
o All suspension parts sanded and coated with “POR 15” to original factory specs.
o Calipers/Brake Drums/Brake Lines Painted
o Driveshaft sanded and coated with” POR15”.
o Sway bars removed and powder coated.
o Exhaust wet sanded with 600 and 2000 grit sandpaper and polished to new finish.
o There is not a spec of dirt or grease on the undercarriage. Everything polished and highly detailed.
Miscellaneous
• California Black Custom Car Cover (will fit light bar and spotlight)
• 1993 Owners Manual and Special Service Police Supplement
• Keychain
• Winterpark PD Graphics/Decals (made by original supplier, Graphic Imaging FLA, permission from Winterpark PD)
• Window Tint (“50” performance tint)
Performance
(Wanted to keep factory with hidden/tasteful performance mod’s that can be turned back to original)
• B&M Transmission Shift Kit
• Ford Racing Headers (non-ceramic to look exactly like factory)
• 3.55 rear gears (Installed by Winterpark PD)
Collectables
• 1993 Ford ABS Police VHS Tape
• 1:18 Scale Mustang New York State SSP
• 1993 Ford Mustang Brochure
• 1993 Ford Mustang Police Interceptor Brochure
• 1993 Ford Mustang SSP Order Form
• 1993 Ford Crown Victoria Police Interceptor Brochure
• 1993 Ford Taurus Police Interceptor Brochure
Winterpark PD
Frank Johnson (Fleet Manager)
407-599-3593
wjohnson@cityofwinterpark.org
Year: Agency: Unit #: Tag #: Last 6 VIN: DSO: Color code: Owner: Notes:
1993 Winter Park, FL PD 1017 147059 27-0409 WB
Barry
"Future Is What Present Does"
Collectables:
Other(s):
1995 Corvette ZR1 (859 miles)
"Kiddie Carrier"
Old 01-24-2008, 05:25 PM
The car looks great!!
Old 01-24-2008, 08:49 PM
Old 01-24-2008, 09:44 PM
Looks like you did it the right way. Very nice.
Old 01-25-2008, 03:23 PM
Mustang Crazy's Avatar
Mustang Crazy Mustang Crazy is offline
Looks good!!!
'89 FHP Unit #1623
'89 FHP Unit #Unknown
'91 FHP Unit #1395
'93 FHP Unit #1660
'91 GSP Unit #1245
Old 01-25-2008, 04:31 PM
Very, very nice job but please tell me those "Poilice Interceptor" badges on the sides will be going away.
Old 01-25-2008, 11:53 PM
WSP-SSP's Avatar
WSP-SSP WSP-SSP is offline
Thumbs up ssp
very very nice work, car is beautiful, concur on them there 5.0 no badges... lol
Mike Jakubec
1990 WSP Commercial Enforcement Mustang
927WSP
http://public.fotki.com/WSP-LXMike/
Old 01-27-2008, 08:11 AM
Alibi
Wink Thanks!
Thanks for the feedback guys. I have much time in the SSP already with more to go. I should have the interior in this weekend as we just completed a custom bracket to istall the lightbar controller under the radio (I added the pics to my photo album link).
Are those 5.0 Interceptor emblems....survey says......yup. Can switch it back no big deal.
Enjoy the weekend. Will keep you posted as I add pics when interior is complete.
Barry
Collectables:
Other(s):
"Kiddie Carrier"
