Old 01-23-2008, 09:32 PM
Winterpark SSP's Avatar
Alibi
Thumbs up Winterpark SSP-Update
This list keeps getting longer, so here it goes I promise pics will be here soon!
1993 Winterpark Florida SSP (72K Miles)
• Synthetic Oil Change
• Rear End Fluid Change
• Brake Fluid Flush
• Power Steering Fluid Flush
• Antifreeze Flush
• 134A A/C Charge
• Spark Plugs/PCV Valve/ Air Filter/Spark Plug Wires/Fuel Filter
• Distributor Cap and Rotor
• Oxygen Sensor(s)
• Serpentine Belt
• Stabilizer Bar Links
• Steering Rack Boot(s)
• Coolant Overflow Bottle
• 130 amp alternator
• Rear Shocks
• All vacuum hoses including vacuum harness
• Valve Cover, Plenum and Throttle Body gasket(s)
• 4 Wheel Alignment and Wheel Balancing
Replacement Parts
• Interior Carpet
• Trunk Carpet
• Shifter Trim Plate
• Bumper Cover Emblem (front)
• Interior Floor Console
• Speakers
• New Air Box and Fender Studs
• Factory OEM Floor Mats
• Polished 5.0 Plenum Plate
• 2 Factory Center caps
• Oil Cap
• Power Steering Cap
• Radiator Cap
• Brake Pedal
• Hood Stops
• 5.0 Emblems and “LX” trunk emblem
• OEM Headlamps/Marker Lamps/Parking Lamps
• New Lenses for Vector Light Bar
• Lenses for “Sho-Me” deck strobes
• New 75W Strobe Power Pack (upgraded from 25 watt)
• Powder Coated 10-Hole Rims
• New Federal Signal PA300 Siren
• Motorola Spectra UHF Mobile Radio and Speaker
• Galls Headlight Wig-Wag Flasher (3x per second)
• 4” Trunk Antenna
Restoration (too much to list)
General highlights:
Engine Detail: (100 + Hours)
• Powder Coating:
o Valve Covers; Plenum; Throttle Body; Mass Air Flow Sensor; A/C Compressor 7 Bracket; Power Steering Pump; Smog Pump; Charcoal Canister; Hood Latch and pulleys.
o Cleaning: Underside of hood, all nuts/bolts, sheet metal, firewall etc.
Undercarriage Detail: (60 Hours)
• Cleaning:
o Undercarriage covered in high strength all purpose cleaner and pressure washed with hot water to remove all dirt and debris.
o Wheels removed and cleaned and polished inside and out.
o All suspension parts sanded and coated with “POR 15” to original factory specs.
o Calipers/Brake Drums/Brake Lines Painted
o Driveshaft sanded and coated with” POR15”.
o Sway bars removed and powder coated.
o Exhaust wet sanded with 600 and 2000 grit sandpaper and polished to new finish.
o There is not a spec of dirt or grease on the undercarriage. Everything polished and highly detailed.
Miscellaneous
• California Black Custom Car Cover (will fit light bar and spotlight)
• 1993 Owners Manual and Special Service Police Supplement
• Keychain
• Winterpark PD Graphics/Decals
• Window Tint (“50” performance tint)
Performance
(Wanted to keep factory with hidden/tasteful performance mod’s that can be turned back to original)
• B&M Transmission Shift Kit
• Ford Racing Headers (non-ceramic to look exactly like factory)
• 3.55 rear gears (Installed by Winterpark PD)
Collectables
• 1993 Ford ABS Police VHS Tape
• 1:18 Scale Mustang New York State SSP
• 1993 Ford Mustang Brochure
• 1993 Ford Mustang Police Interceptor Brochure
• 1993 Ford Mustang SSP Order Form
• 1993 Ford Crown Victoria Police Interceptor Brochure
• 1993 Ford Taurus Police Interceptor Brochure
Winterpark PD
Frank Johnson (Fleet Manager)
407-599-3593
wjohnson@cityofwinterpark.org
Year: Agency: Unit #: Tag #: Last 6 VIN: DSO: Color code: Owner: Notes:
1993 Winter Park, FL PD 1017 147059 27-0409 WB
Barry
"Future Is What Present Does"
Collectables:
Other(s):
1995 Corvette ZR1 (859 miles)
"Kiddie Carrier"
