Old 12-04-2007, 07:59 AM
Winterpark SSP's Avatar
Alibi
Thumbs up Winterpark FL SSP-Progress List
Whats Up Guys!
Here is the list of what has been completed on my car thus far. There will be more to come as I plan on taking this car to concouse level.
1993 Mustang Winterpark Florida SSP
• Synthetic Oil Change
• Rear End Fluid Change
• Brake Fluid Flush
• Power Steering Fluid Flush
• Antifreeze Flush
• 134A A/C Charge
• Spark Plugs/PCV Valve/PCV Valve Filter/Spark Plug Wires/Fuel Filter
• Distributor Cap and Rotor
• Serpentine Belt
• Radiator Cap
• Coolant Overflow Bottle
• 130 amp alternator
• Rear Shocks
• All vacuum hoses including vacuum harness
• Valve Cover, Plenum and Throttle Body gasket(s)
Replacement Parts
• New Air Box and Fender Studs
• Factory OEM Floor Mats
• Polished 5.0 Plenum Plate
• 2 Factory Center caps
• Oil Cap
• 5.0 Emblems and "LX" trunk emblem
• OEM Headlamps/Marker Lamps/Parking Lamps
• New Lenses for Vector Light Bar
• Lenses for “Sho-Me” deck strobes
Restoration
Engine Detail: 100 + labor hours
• Powder Coating:
o Valve Covers; Plenum; Throttle Body; Mass Air Flow Sensor; A/C Compressor 7 Bracket; Power Steering Pump; Smog Pump; Charcoal Canister; Hood Latch. Every bolt, nut has been detailed and painted. The engine bay can be eaten off of!
Miscellaneous
• California Black Custom Car Cover (will fit light bar and spotlight)
• 1993 Owners Manual and Special Service Police Supplement
• Keychain
• New Federal Signal Microphone
Performance
• Transmission Shift Kit
• Ford Racing Headers (non-ceramic to look exactly like factory)
• Hella Headlight Bulbs
• 4 Wheel Alignment and Wheel Balancing
Collectables
• 1993 Ford ABS Police VHS Tape
• 1:18 Scale Mustang New York State SSP
• 1993 Ford Mustang Brochure
• 1993 Ford Mustang Police Interceptor Brochure
• 1993 Ford Crown Victoria Police Interceptor Brochure
• 1993 Ford Taurus Police Interceptor Brochure
Barry
"Future Is What Present Does"
Collectables:
Other(s):
1995 Corvette ZR1 (859 miles)
"Kiddie Carrier"
Old 12-04-2007, 08:44 AM
Unmrkd's Avatar
Unmrkd Unmrkd is offline
Resident Geezer
Barry, sounds like you are moving right along with the car. Lots of labor involved with the underhood detailing. Where did you source the vaccume harnesses? I'm looking in particular for the block harness that has the connectors/hoses for the EGR valve, smog pump etc on the passenger side of the engine. Thanks, and enjoy your car.
Gregg
'89 FHP Unit # 435 (Deceased)
Old 12-04-2007, 04:18 PM
Alibi
Smile Vacuum Harness
Time to take a stroll to the local bone yard or shop Ebay (that's were I located mine). The vacuum lines disconnect from the harness plug, thus you can mix and match to make a complete set.
Good Luck!
Barry
Barry
Collectables:
Other(s):
"Kiddie Carrier"
