Old 03-14-2019, 03:53 PM
usajay38's Avatar
usajay38 usajay38 is offline
Default Help code door tag for 1989 FHP (maybe)
Help decode this door tag I need to know as much info as possible.
Thanks
File Type: jpeg BC757E52-2A2B-4A04-8170-1B3A78FB9844.jpeg (120.3 KB, 36 views)
1991 Ford Mustang GSP SSP #1195-Sold
1988 Ford Mustang FHP SSP
1997 Ford Mustang GT--wrecked
1990 Ford Mustang Avis SSP--sold
Old 03-14-2019, 11:02 PM
9L = Oxford White
KF136252 is not part of a >3 grouping of V8 notchbacks.
24 on the DSO indicates it was ordered through the Jacksonville, Florida office.
6-digit DSO number indicates it was a special order.
Old 03-15-2019, 09:07 AM
This VIN is a 'single' P40E. The VIN before it was an LX 5.0 hatchback and the VIN after it was an LX (2.3L) hatchback.
1FABP40E7KF136252
---------1---------
We will need the buck tag or other supporting documentation to verify that it is an SSP. Having a special order DSO does not make automatically make it a SSP.
Old 03-15-2019, 09:25 AM
1FA = Ford passenger car manufactured in USA by Ford Motor Company
B = active belts, no airbags
P = passenger car
40 = Mustang LX 2-dr sedan (coupe)
E = SEFI H.O. 5.0L V8 engine
7 = VIN check digit
K = 1989 model year
F = Dearborn Assembly
136252 = 36,252nd 1989 Ford scheduled for production at Dearborn Assembly
Date - 11/88 = November 1988 build
GVWR - 4230 lb/1918 kg = gross vehicle weight rating
Front GAWR - 2262 lb/2031 kg = front gross axle weight rating
Rear GAWR - 1026 lb/921 kg = rear gross axle weight rating
F0138 = 138 lbs front accessory reserve load
R0161 = 161 lbs rear accessory reserve load
Exterior Paint Colors - 9L = Oxford White
DSO - 240018 = Jacksonville district sales office (24), 1989 special order #0018 in the Jacksonville DSO
Body - 66B = Mustang LX 2-dr sedan (coupe)
Mldg - XXX = Black bodyside molding with no insert stripe
Int Trim - FY = cloth seating, low-back front buckets (F), Sand Beige interior color (Y)
Tape - Y = Medium Champagne bodyside paint stripes
R - 9 = electronic AM/FM stereo search radio with cassette tape player and clock
Ax - M = 2.73:1 ale ratio, Traction-Lok differential
Tr - T = Ford automatic overdrive (AOD) transmission
RR = front springs
SS = rear springs
Old 03-15-2019, 10:30 AM
usajay38's Avatar
Wow, white exterior, sand interior, auto. I may be getting this one.
Thanks
Old 03-15-2019, 12:24 PM
Even if no SSP, it sounds like a nice car.
Old 03-16-2019, 05:03 PM
usajay38's Avatar
Getting closer
File Type: jpg E5E033E0-19B4-4E35-B664-8ADF37B7E73D.jpg (8.8 KB, 25 views)
Old 03-19-2019, 08:24 PM
It does not have a police branded title in Florida, which doesn't mean all that much.
Old 03-19-2019, 09:53 PM
usajay38's Avatar
Carfax not showing registration from 1989 to 2000. Don’t know if that means anything. Seller is checking for buck tags tomorrow, stay tuned!
