Old 11-12-2017, 02:59 PM
crispiniscool crispiniscool is offline
Default 1984 Florida Highway Patrol SSP
Relisting this because my craigslist AD I linked to is no longer active. I moved to Montana, this car is at my parents house in upstate NY. The car has set of assembled pro comp aluminum heads, hedman headers, tune up stuff, new hoses, HEI dizzy, etc that'll come with it too.
The Good:
Former Florida Highway Patrol car. No rust on the undercarriage or quarters. Little bit of surface rust on the drivers fender. Was repainted black in 2008 (used to be Black and Tan). Never seen snow. Original drive train. 3.08 posi from the factory. Original 5.0 5spd car. I have all the radios and lights for the car (uninstalled) also have unused Florida Highway Patrol decals for the doors and hood. Has just about 75k on the odometer.
I have tons of maintenance records and a Marti report on the car and an original build sheet. New coil, serpentine belt, and idler pulley this summer. Oil changed every 3k or start of the season.
Original AC car. Not a perfect car but a very solid SSP foxbody with a some pretty rare options (most SSP's have been turned into drag cars because of the factory reinforcement and/or were automatics.)
The Bad:
Motor needs piston rings and a tune up (got brand new motorcraft plugs, wires, dizzy cap and rotor in boxes)
Needs paint - the paint job in 08 has not held up. Has several chips on the driver side and slight dings and imperfections throughout.
They did not paint the jams or the inside of the trunk when it was resprayed.
Interior is pretty clean, dash is cracked, driver seat has a tear, and the trim is all faded. Plus there are holes where the radios and stuff were screwed in.
It doesn't have A/C lines or a condenser - it does have a compressor tho (not sure if it works obviously).
Modifications:
Sometime between when it was delivered to the FHP and 2008 it has a hood scoop put on it -- I think it looks mean as all hell personally, but it wasn't original to the car according to the build sheet.
"Powered by Ford" finned valve covers
Accel Superstock Coil
Asking $5800.
Pictures: THERE ARE A TON OF PICTURES IN THESE FOLDERS!
Exterior and Interior pictures
Undercarriage and misc pictures
Pre-2008 paint job pictures
Old 11-13-2017, 10:48 AM
Looks like a great car. Good luck with the sale.
Old 09-25-2018, 11:28 AM
NYSSP F NYSSP F is offline
Where in upstate NY?
Old 09-30-2018, 06:53 PM
Agreed...best wishes.
Old 10-01-2018, 09:21 AM
mustangpro mustangpro is offline
I'm picking this car up in a couple of weeks!! More soon.....
79 Capri RS 5.0/AOD | 82 CHP SSP #0513 5.0/SROD | 82 Capri Tu-Tone 4.2/C5 | 83 NCSHP SSP 5.0/SROD
84 FHP SSP 5.0/T5 | 85 LTD LX 5.0/AOD | 86 LTD Brougham 3.8/C5 | 88 GT 5.0 Turbo/T5
Old 10-02-2018, 09:43 PM
Way to go Chris! So glad you're getting it!
Old 11-04-2018, 05:49 PM
How did the trip to pick up the car go and what are your plans with this one?
