Old 04-02-2016, 09:21 AM
Bert Cooper Bert Cooper is offline
Default Did Ford stamp VIN's anywhere but the dash tag ?
Can anyone tell me if the 87 to 93 Mustangs have their VIN stamped anywhere in visible location (not including the dash tag).
I'm aware of the various VIN labels on sheet metal components, but are there any other permanent stamps?
Many thanks!
Bert
Old 04-02-2016, 07:20 PM
smunczen's Avatar
smunczen smunczen is offline
Engine block and transmission.
82 CHP Unit#870366
86 TX DPS M6-380
Old 04-03-2016, 08:24 AM
Main ones are under fenders. Very hard to see bewitch a flashlight look through opening in front of splash shields (fender liners) about a foot and a half from front edge of fenders (on the bottom side) easier if fender liners are off.
Old 04-04-2016, 12:41 PM
Wow, the complete VIN is stamped on the transmission and engine block? Interesting.
Can anyone direct me where to look for the VIN on these components?
Thank you,
Bert
Old 04-04-2016, 12:50 PM
No, only a partial VIN on the engine and trans. Same for the tags on the inner fenders and the buck tag. Only place you will find a full VIN is the plate on the upper firewall (visible through windshield), the door tag, and the sticker on all of the major body panels (1987+ only).
Old 04-04-2016, 12:52 PM
VIN on engine block is on the flat pad behind the (lower) intake manifold
VIN on the T-5 manual trans -- I haven't been able to find one on the AOD yet -- is on the passenger side of the main case, where it bolts to the clutch housing
Old 04-04-2016, 12:54 PM
Old 04-04-2016, 12:55 PM
