Old 11-23-2015, 03:49 PM
Default 1989 Claimed SSP on CL (over $50K invested)
Not mine - an ALL CAP warning has been issued.
https://dallas.craigslist.org/dal/bar/5299542918.html
5.0 Mustang LX, SSP Notchback 89' (Dallas tx)
Over $50,000 invested fully built from rear end to throttle body, 453 hp to the wheel naturally aspirated: D.S.S. BOSS BLOCK 331 stroker,ALL FORGED INTERNALS WITH DSS GIRDLE, 4 BOLT MAIN, UP TO 800 HP CAPABLE, 11.5:1 COMPRESSION, AFR 185s 58CC. RENEGADE heads, RACE OIL PAN, ALL PULLEYS, POWER STEERING, NO A/C, HOLLEY SYSTEMAX 2 INTAKE MANIFOLD, 90MM ACCUFAB POLISHED THROTTLE BODY, ANDERSON MOTORSPORT 4'' POWER PYPE COLD AIR INTAKE, 90MM SCT MAF, ANDERSON MOTORSPORT N-71 HI-REV CAM,7K RPM RED LINE, SCORPION SPRINGS, RETAINERS, 1.6 ROCKERS, ARP PUSH RODS, ARP STUDS, COMETIC HEAD GASKETS, UNDER DRIVE PULLEY DAMPENER, HOLLEY FUEL REGULATOR W/ GAUGE, 34# FFRP INJECTORS, 255 LPH FUEL PUMP, BBK LONG TUBE HEADERS, X PIPE OFF ROAD, SUPER 44 FLOWS WITH LX TAIL PIPES, FRRP 3.73 GEARS, POSI-TRAC, 31 SPLINE AXLES, WELDED AXLE TUBES, PRO KIT LOWERING SPRINGS, KYB ADJUSTABLE SHOCKS ALL AROUND, SUB FRAME CONNECTORS WELDED, UPPER AND LOWER CONTROL ARMS REAR, FFRP ALUMINUM DRIVE SHAFT, UPGRADED YOKE, 26 SPLINE, SPEC BELL HOUSING, SPEC BILLET FLY WHEEL, SPEC STAGE 3+ CLUTCH, TKO 600 DRAG SPEC TRANSMISSION, TRI AX SHORT SHIFTER,3 CORE RADIATOR, FLEX A LITE ELECTRIC FAN, MSD DISTRIBUTOR, WIRES ETC. 15X10.5 WELD WHEELS REAR, 15X3.5 FRONT, MICKEY THOMPSON E.T. STREETS REAR, MICKEY THOMPSON SPORTSMAN FRONT, 5 LUG CONVERSION (2004 GT) BRAKE ROTORS AND CALIPERS, BLACK INTERIOR, LIMO TINT, DRAG RACE STEERING WHEEL, ALL AUTO METER GAUGES PRO COMP 3 POD AND "FLORIDA 5.0" AUTO METER GAUGE CLUSTER, HID 5000K HEADLIGHTS NEW LIGHT HOUSINGS ALL AROUND, 10.80S IN THE QUARTER MILE ONLY WEIGHS 2700 LBS. LIKE A DAMN HONDA. MUCH MORE TO LIST,TURBO, SUPER CHARGER OR NITROUS READY! TUNED BY HPP PERFORMANCE IN DALLAS TX, FEEL FREE TO TEXT OR CALL TO MAKE offer OR open to trades.
call or text (2one0) 724-02two-five
