Old 10-13-2014, 02:07 PM
joefernandez joefernandez is offline
Question Feedback on Sand Beige fabric from SMS Fabrics
Have any of you used the Sand Beige fabric from SMS Auto Fabrics ? I received my samples but they seem a little bit darker than the actual fabric on the car. Any help or suggestions would be appreciated. Thanks
Old 10-13-2014, 02:56 PM
Original fabric is obviously subject to fading over time. Make sure you're checking the sample to a section of original fabric that has not been exposed to years of sun.
The smoke grey fabric I got from SMS was a dead match.
Old 10-14-2014, 01:27 PM
Venomizd93 Venomizd93 is offline
SMS is probably your best bet for OEM original, I have gotten samples for the infamously hard to get SVO insert material(a black square dot and gray background pattern) and it is a dead on match(compared to unfaded original). It's not cheap but I'd go with what they sent you as a match. It seems like at least one other person here has had good luck with them.
Old 10-15-2014, 07:07 AM
ccmcelroy's Avatar
ccmcelroy ccmcelroy is offline
Default Feedback on Sand Beige fabric from SMS Fabrics
I will give my two cents worth as well. I purchased SVO material for my 1986 and Crystal Blue material for my 1990 from SMS and they are both spot on. As stated above a little expensive but if you want it to be correct it is the way to go.
Chad McElroy
1990 Trussville Alabama SSP
1986 Mustang SVO Bi-Wing delete
Old 10-15-2014, 10:51 AM
Thanks for all the help guys.
