Old 10-03-2014, 10:51 AM
Default 1986 possible CHP on CL
It may not be a SSP, but the seller has a way with words
https://losangeles.craigslist.org/sg...695864181.html
1986 Mustang Notchback with a bunch of goodies. Car was painted about 3 years ago and now needs a new paint job. ****Pictures are outdated, taken 2 years ago**** I'll update later when I'm dropping a deuce.
-306 with GT40 Heads
-o.e.m. Saleen Vortech Intake Manifold
-24lb Injectors
-5 Lug Conversion w/ extended studs all around
-28 Spline Moser Engineering Axles
-4.10 Gears with Auburn Diff in 8.8 Rear
-Lake wood race shock with Struts set up for drag
-Eaibach drag spring
-Full Subframe Connectors
-Ford Rear Diff Cover
-Rear upper control arms Lower are adjustable for bigger tire
-Orginal Black Interior
-Aluminum Drive Shaft
-Bullitt rims 17/9 front 18/10.5 Rear
-Aluminum radiator w/Electric Fan
-MsD box
-Engine Bay Wire Tuck
-Removed Bumper Core and Door Metal for weight loss
-Trick flow 2 Cam with TFS 1.6 RR
-updated computer with /Mass Air
Car runs very good!!! Air/fuel is set right for 91 pump gas. Come test drive or ask any other questions. Tags are up to date, clean title, no trades. Call 626-549-8076
