Old 04-15-2014, 03:31 AM
Rhino's Avatar
Rhino Rhino is offline
Default 1989 WSP SSP - Tacoma, WA
All,
A local friend is selling his 1989 WSP Mustang. The car was likely part of the commercial enforcement program when in-service. It originally had the same "fleet blue" repaint over white like Mike J's car when purchased. The car is located in Tacoma, WA.
Diego rarely gets on the forum and has been busy with work. He asked if I would post up his info on the car to see if any interest. You can contact him via the info below. I have seen this car a number of times over the years, and it would be a nice/solid start for either restoration or as a fun driver.
More pics/info as they come in.
Details:
  • 1989 Ford Mustang
  • Mileage: 160,912
  • Engine: 5.0L V8
  • Transmission: 5-Speed Manual
  • Former Agency: Washington State Patrol
  • Power windows/locks & mirrors
Upgrades:
  • Short throw shifter
  • Quick ratio rack & pinion
  • 3.08 rear differential gearset
  • Electric fan with 3G alternator
  • Trick Flow stage 1 camshaft
  • Aluminum cylinder heads & roller rockers
  • BBK full length headers & H-Pipe
  • Flowmaster cat back exhaust
  • 5-lug conversion with SN95 front disc brakes & Aerostar rear axles
  • 2001 Ford Mustang GT 17" wheels
  • Recent paint - Decent driver quality, but may need to be upgraded down the road.
  • Recent new clutch
What need to be fixed/looked at:
  • Will need tires soon
  • Should have an alignment
  • Interior is consistent with age and agency use - could use a refresh
  • Rear diff has a worn out clutch pack and bad pinion bearing
  • Exhaust seems rich with fuel mix - lambda meter shows perfect ratio
  • Drives rougher at lower speeds due to larger throttle body - runs better at higher speeds above 25 MPH
  • Cam related idle surge (to be expected).
Seller's contact info:
Diego - 253-359-4331
Price: $3500 or Offer
Pics:
Ryan
Old 04-15-2014, 07:08 AM
92NM-SSP's Avatar
92NM-SSP 92NM-SSP is offline
Default mustang
looks like she mite have a new owner already,talking with diego now,thanks for the post Rhino
Old 04-15-2014, 12:59 PM
92NM-SSP's Avatar
Default mustang
shes mine now,,thanks
Old 04-15-2014, 01:08 PM
Congrats on the new SSP!
We only have one 1989 WSP in the VIN Project currently (which I do not believe is your new SSP)...
http://www.specialservicemustang.net...info179295.htm
...so once you get the car if you can post up some photos of the VIN label and/or Buck Tags we will add this one too.
Old 04-15-2014, 01:37 PM
Rhino's Avatar
Thumbs up
Wow - that was FAST!
Hope it all works out. And happy I was able to connect you guys.
Ryan
Old 04-15-2014, 07:16 PM
92NM-SSP's Avatar
Default ssp mustang
I was waiting for it :-)
Old 04-15-2014, 07:30 PM
92NM-SSP's Avatar
Default vin#
VIN#
Old 04-16-2014, 12:37 AM
67gt500 67gt500 is offline
Congrats! Looks like a great start!
Old 04-19-2014, 03:46 AM
92NM-SSP's Avatar
Default buck tags
buck tags
Old 04-19-2014, 03:57 AM
92NM-SSP's Avatar
door sticker
