Old 03-23-2014, 10:58 PM
stangman86uhp's Avatar
stangman86uhp stangman86uhp is offline
Default 1986 ssp
http://forums.corral.net/forums/must...hci-410-a.html
Old 03-24-2014, 12:10 AM
Quoting the ad -
1986 SSP LX Coupe HCI
I'm the third owner of this car, had it for a little over 2 years. When I got it, it was 100% stock with speed density efi and all 4 cats. It has been hit in the right front and the PO replaced the front clip as seen in the pics, still needs to be painted. It was originally a Washington State police car, so she has some dings and wear on the body, but it drives and tracks straight. I just did an alignment on it after putting the manual rack in, no issues found there.
Only rust is in the trunk lid and its minimal.
Engine is a 60K mile 93 Cobra short block with:
TF Twisted Wedge heads
TFS R intake
BBK 75 mm TB
N41 cam and valve train bits(custom length pushrods, 1.7 rockers, etc) from Anderson
New water pump and timing chain installed when cam went in
24 lb 93 Cobra injectors and Cobra MAF
A9L ECU
BBK Ceramic 1 5/8 Long tubes and X pipe with WB bung
2.5 in Flow masters with 2.5 LX tips
LMR 3 row radiator
3G alternator
A/C deleted
P/S deleted with MM shaft and FR Rack
No smog of any kind
made 327/330 on a dyno jet, untuned.
Idles at 14.7 and runs flawlessly, very fast!
Other Parts of note:
MM Full length SFC
Spec stage 2+ Clutch and aluminum flywheel
Clutch quadrant and Firewall adjuster
TKO 500 trans
MGW shifter
FMS aluminum drive shaft
FMS 4:10 gears professionally installed, with clutch pack mod, Speedo gear
Tubular lowers, stock uppers
Eibach springs
Urethane control arm bushings, KYB shocks/struts
Ranger axles and drums (5lug)
SN95 front disk(5lug)
3" wheel studs
255 pump
5 lug spare in the trunk
I have all the moldings and 2 sets of front spats for the fenders.
Factory driver seat will go back in and the Wideband will come out before the sale. Needs heater core replaced, but a NIB ford core is included in sale.
$5500 469.235.3806 I prefer text or PM please.
Car is in North Texas
Report this image
Report this image
Report this image
Report this image
Report this image
Report this image
Report this image
Report this image
Video of idle
https://www.youtube.com/watch?v=40Ha...ature=youtu.be Digsby
IM, Email, and Social Networks in one easy to use application!
http://digsby.com
Digsby
http://digsby.com
Digsby
http://digsby.com
Digsby
http://digsby.com
Digsby
http://digsby.com
Digsby
http://digsby.com
Digsby
http://digsby.com
Digsby
http://digsby.com
86 SSP with some stuff on it.
Old 03-24-2014, 12:43 AM
Mnstr50 Mnstr50 is offline
Drool, four-eye notch! Good luck with the sale.
Old 03-24-2014, 10:41 AM
Default 86ssp
not mine just found on the site.
Old 03-24-2014, 10:42 AM
I sent the seller a PM to ask for photos for our VIN Project.
Old 03-24-2014, 10:55 AM
The seller got back to me and confirmed that the previous owner already provided pictures for our VIN Project:
http://www.specialservicemustang.net...info197814.htm
Old 03-24-2014, 02:24 PM
great glad to see it has been documented!!
