Old 01-19-2014, 09:52 PM
Default Mass backed carpet??
When I bought the FHP, the PO took the carpet out and put rubber flooring in it. :doh Anyway, I need to buy carpet for it and I noticed ACC has the standard carpet and then they have a "Mass backed" version that's supposedly "closer" to stock. I know that ACC's standard carpet can be hard to lay down right, and it seems a thicker padding would be worse.
Has anyone used this mass backed version or has anyone heard any reviews of it?
Thanks!
Old 01-19-2014, 10:07 PM
I have used it in the PA car. It was a lot easier to install than the regular carpet that I put in my 94 veret. I did find some spots where the pile was not as thick as it should be. I also took the carpet out of the box and laid it out flat over night. This helped to make it easier to install the carpet.
Old 01-19-2014, 10:10 PM
Yep, laying flat and even laying out in the sun helps too. So it was easier than standard to install huh? Thanks for the review, I may just try it.
