| Special Service Mustangs For Sale Any and all SSP Mustangs. |
Thread Tools | Display Modes |
1991 Mustang FHP # 726 - $11500 (360 Otterdale)
© craigslist - Map data © OpenStreetMap 1991 ford mustang odometer: 104371 VIN: 1FACP40E9MF141332 manual transmission For sale is my beloved 1991 FHP #726. I bought it at a Fla state auction in 1996 and used it as a driver and promotional car for my Mustang restoration business until 06 when she was put in to storage. In 2011 she was disassembled and did a PPG repaint and drive train rebuild. Ever piece on it has been reconditioned or inspected or replaced and I have personally done all the work or supervised it, some work was done prior to 2011. I have collected Mustangs for 40 years and was involved in restoration of 64.5 postage stamps Mustang. I have documentation and history of #726. And tons of paper work, such as picture documentation. As I, have moved from 6 car garage to a 2. I have no room for her. You can contact me by phone only 540/580/1252 Car is in Richmond Va. Inspections welcome. The following is partial list of work done. Body, paint, and engine work was done in June 2011 mileage 101,705 current 104,371. Body and Paint - Disassemble car, hand sand body, prime and seal, painted in base coat, clear, PPG factory FHP colors. Paint door jams and all under surfaces of hood and trunk. Remove engine and paint engine compartment. Install nos front bumper cover. R&I and paint body side moldings. Paint front, rear windshield trim, door handles, cowl. Install all new body emblems. Install pair of Ford nos roof rail moldings. Install door weather stripping, hood weather stripping, and paint lower window moldings. Strip wheels and clear. Install new nos quarter glasses. Install front Carlite windshield. Replace hood due to bad repair by FHP maintenance. Touched up chip edge passenger door. New Ford hood insulation. Engine - Disassemble engine. Install standard rings, bearings, timing chain set, performance products, harmonic balancer, set of roller lifters, work heads, deck, cam bearings, polish crank, oil pump, plugs, motor mounts, wires, cap, rotor button, negative battery cable, motorcraft battery, detail engine, rebuild starter, alternator. Motorsport water pump, PCV valve, hose, retainer, serpentine belt, coil, solenoid, A9L computer, hi flow H pipe, have original cats. Flowmaster mufflers, tailpipes, Ac condenser, dryer, converted to 134A,. Power steering pump, rack, power steering hose. Heater core, hoses. Fuel pump. NOS oil cooler setup. Flow master mufflers, new tailpipes. Use Amzoil in engine, Trans, diff. Drive train and suspension - Motorsport clutch assembly, flywheel, T5 release bearing support, front and rear seal. Steeda triax shifter. Steeda clutch quadrant assembly. Aluminum drive shaft. Rear disc brakes 3.55 gears with correct Speedo gear, subframes, strut tower brace, K frame brace, lower Steeda control arms, upper Motorsport control arms, Steeda caster camber plates, custom alignment. A set of 225/60/15 Cooper tires. Front disc brakes are Mark 7 calipers, stainless steel lines, caliper bushings, and performance friction brakes, slotted rotors, seals, and bearings. 95 GT master cylinder and prop. Valve. New calipers rear, hawk pads, new seals. Tokico 5 way adjustable shocks and springs. Cobra shift knob, lower trans boot, radiator and hoses. Motorsport tac, oil, temp gauge cluster. Interior -Remove and clean all parts, install new headliner and deck board. Bought new seat covers and carpet, but they were terrible quality, so I cleaned the original interior and reinstalled. Some wear on top of rear seat and tear on back of driver seat in the vinyl. Floor mats, update radio. Mustang has current VA inspection sticker, and clear VA title. http://richmond.craigslist.org/cto/4282314107.html
1988 Mustang LX |
The phone number for the seller-
Chris 540-580-1252
1988 Mustang LX |
Like any used car, make sure you see it in person before you buy it.
Car is back on EBAY.
1988 Mustang LX |
Its gone! Went for $10200. It drove like new and had lots of nice upgrades!!
Greg 1987 TX DPS # M7-417 1992 FHP 1993 LX 5.0 Notch 1995 Lightning 2002 Lightning |
Did you buy it?
1988 Mustang LX |
Nope, bidding frenzy near end of auction, you know how that goes!
Went to ck out Kapracing's 1990 CHP yesterday, nice car, super guy, knows his stuff on these cars, an authority when it comes to GSP. Met him and his wife, really good people!!! Fun 4 hour round trip into NW Georgia, drove my 87 TX car, enjoyable experience!!!
Did he change his mind on selling or did it sell? Sounds like a good trip.
1988 Mustang LX |
