Old 08-19-2013, 08:01 PM
Default 1988 GSP (JF225817) on ebay
Last one in a group of 100. Already in the VIN Project.
http://www.specialservicemustang.net...info225817.htm
Item Location: Winston, Georgia
Time left: 6d 01h (Aug 25, 201316:00:00 PDT)
Bid history: 12 bids
Current bid: US $5,100.00
Condition: Used
Seller Notes:"Windshield has crack along bottom, currently driving because its not in the line of sight.Wiper cowl is bent due to hood coming up, which also caused the cracked windshield."
Make: Ford
Model: Mustang
Mileage: 103,553
Sub Model: LX
Interior Color: Black and Grey
Number of Cylinders: 8
Transmission: AOD w/PA HOLD valve body and TFS pan
Body Type: Sedan
Vehicle Title: Clear
Options: CD Player
VIN: 1FABP40E5JF225817
Safety Features: 4 Wheel disc brakes with adj prop valve
Power Options: Air Conditioning, Power Locks, Power Windows
Fuel Type: GAS
For Sale By: Private Seller
Warranty: Vehicle does NOT have an existing warranty
Year: 1988
Trim: LX
Engine: 5.0L HO
Drive Type: RWD
1988 Foxbody Mustang Coupe LX 5.0
Drivetrain and suspension
5.0 engine, factory, bone stock internally
New oil pan (I pulled motor when I bought the car and went through all the wiring harnesses. The main engine harness was replaced. All other wires were inspected and rel-oomed. When the pan was pulled and motor out I inspected the internals as much as possible. Timing chain is still tight with no slack. Cross hatching can still be seen in the cylinder walls. No smoke from engine, doesn't use oil. New rear main seal installed)
New sensors installed.
Passes emissions with timing set at 12 degrees timing. I run it at 14 with premium fuel.
Starter converter to gear reduction from SN95
140 amp alternator upgraded with proper size battery cable and in line fuse to support the electric fan with thermostatic on/off and additional toggle switch.
New MSD Blaster coil
New TFI module
New radiator
Fenderwell cold air intake
ASC aluminum underdrive pullies
BBK x-pipe with cats
2.5" Pypes stainless steel exhaust
AOD tranny with PA valvebody and shift kit
Trick Flow aluminum deep sump pan with drain
New Stainless steel transmission lines
FMS aluminum driveshaft
4.10 FMS gears with new posi trac differential and trick flow girdle cover
5 lug disc brake conversion from 95 GT
Front 5 lug conversion with spindles from 01 GT. Aluminum dual piston calipers and new wheel hub assemblies
Baer Brakes adjustable proportioning valve
Brake Booster and master cylinder from 93 Cobra
Eibach sportline suspension.
Polyurethane bushing throughout car
Tubular rear control arms
Tires and wheels from 2001 GT
New front control arms.
New shocks in the rear and struts in the front
Maximum Motorsports caster camber plates
New headlights
4inch cowl hood.
Completely new R 134A AC system from Hoze Wizard. 34 degree AC
They also installed a new heater core.
Interior was converted to black and grey.
Corbeau GTS II seats and brackets
7 inch DVD/CD player head unit. Speakers and amp installed. Will need head unit replaced.
New black carpet. Carpet is called mass back. It has an extra coating for noise and heat reduction
Dash is in good condition
I get between 16-18 mpg running around town. Runs great. I've taken it on trips to Florida, Virginia, and Ohio. I have not had any problems with the car, it gets 20 mpg on the highway running 70-80 miles per hour.
All that's lacking on the car is paint and body work. Due to relocation the car will not be coming with me.
I am not the original owner. I do have the title in hand.
Transport available, I have a friend who will give an honest price based on location if needed. He is a local Tow Truck owner.
$500 dollar payment required upon winning bid. Remaining amount due will need to be in the form of cash or cashiers check.
File Type: jpg $(KGrHqN,!mEFIG!DCc,gBSC4JDKN7w~~60_3.jpg (54.7 KB, 72 views)
File Type: jpg $T2eC16V,!zQE9s3ssVw7BSC4JktCYw~~60_3.jpg (33.4 KB, 44 views)
