Old 08-13-2013, 11:42 PM
octavio's Avatar
octavio octavio is offline
Red face Help i might have a ssp
i got the car because it was an original v8 its a 1989 power windows and locks heard thats rare. also i found the color code is 1d dark grey so i know it wasnt a CHP the DSO # is 71 (LOS ANGELES) the car was made in florida at the dearborn plant i need help finding out what the car was used for if it was ordered by an agency n e help will be apreciated
Old 08-13-2013, 11:54 PM
Can you see the buck tags on the front of the radiator support, down by the drivers side frame rail? Should be able to see them (2 if SSP) if you look down behind the headlight.
Old 08-13-2013, 11:59 PM
octavio's Avatar
sadly it has 1 tag
Old 08-14-2013, 12:03 AM
octavio's Avatar
will this might help vin #176812
Does the DSO only have 71 or is it 71 and 4 more numbers with it? Like Mustang Kid said, open the hood and look down between the core support and the drivers side headlight and see if you can see the buck tags stapled to the radiator support. If so and there's 2 of them, one of them should have the agency that ordered it.
Old 08-14-2013, 12:06 AM
octavio's Avatar
it has only 1 tag and it has 71 not 4 numbers
Old 08-14-2013, 12:09 AM
If it only has 71 for the DSO on the door sticker then its not an SSP unfortunately. Unless for some reason the door was changed along the way. Does the VIN on the door match the VIN plate?
Noticed you also said it was made in Florida at the Dearborn Plant. The Dearborn Plant is in Michigan.
Old 08-14-2013, 12:12 AM
octavio's Avatar
how do i know if t he vin matches the door?
Old 08-14-2013, 12:15 AM
Compare it to the VIN plate on the dash.
Old 08-14-2013, 12:16 AM
octavio's Avatar
yea the vin is the same not a ssp
