Old 10-09-2012, 02:14 PM
93chipper's Avatar
Default crown victoria spotlights in a ssp
will it work i bought a set and im wondering if it will work
93 chp unit 5333
polyurathane motor mounts
1.7 roller rockers
c&L 73mm mass air
Old 10-09-2012, 06:09 PM
Va 5.0's Avatar
Va 5.0 Va 5.0 is offline
good info here:http://www.sspcentral.com/library/unity.shtml
Found in old posts:
The shaft lengths on the CV and Caprice lights are longer than what the Mustangs took but they can be switched out.
Unity spotlight 225K or 225GM will both work. Mount brackets 221 for RIGHT/passenger side, 221RH
Jack
1987 CHP E422920
1988 CHP (sold)
1989 LX Hatch 5.0
1992 UHP
1995 Cobra
Old 10-09-2012, 06:46 PM
93chipper's Avatar
they are from a 2006 crown vic that was wrecked now the lights wont stick out too bad will they
93 chp unit 5333
1.7 roller rockers
c&L 73mm mass air
Old 10-09-2012, 08:05 PM
Jack is right, use those tube #'s ( rods to go through the A pillar ) and use Unity installation kit bracket ( for the outside A pillar ) 221 for the driver side, 221RH for the passenger side.
You will need shorter tubes ( rods ) or they will stick out further in the car, possibly out side of the car as well.
You can still buy these kits from Unity. I believe the tubes also.
The kit comes with instructions. It's pretty easy to do. Just take your time.
Are they brass cone shaped spots ? Or the newer plastic with a flat spot instead of a cone ?
Old 10-09-2012, 08:07 PM
Default correction
Correction..... 221 for the passenger side, 221RH for the driver side.
My bad.
I can't even read my own notes on my part boxs LOL
Old 10-09-2012, 08:10 PM
93chipper's Avatar
plastic buckets also need new handles 1 was missing and the other they cut the wires too short
93 chp unit 5333
1.7 roller rockers
c&L 73mm mass air
Old 10-09-2012, 08:24 PM
Va 5.0's Avatar
Not sure... Measure the A shaft length and compare to the chart.
K shaft are what it should have and GM shafts work
Jack
1987 CHP E422920
1988 CHP (sold)
1989 LX Hatch 5.0
1992 UHP
1995 Cobra
