Old 09-08-2012, 10:48 AM
Default Something about this says SSP to me (1985)
An '85
http://santabarbara.craigslist.org/cto/3240803825.html
Old 09-08-2012, 03:02 PM
84oregonssp's Avatar
84oregonssp 84oregonssp is offline
Has 2 ground straps on hood... hard to see speedo in pic ... could be one undercover as an Aero notch ??
2012 Kona Blue Mustang GT
1985 OSP SSP
1984 OSP SSP
1984 SVO - Project
1969 Mach1 390 S-Code
1966 Mustang Coupe w/ 351w
Old 09-08-2012, 03:22 PM
CHP didn't use auto's did they? The interior color is correct for a CHP. Nice detective work on the ground straps! Totally overlooked those.
Old 09-08-2012, 04:48 PM
Two holes on the dash trim under the vent look like they could have been used for a mic clip, but that would be hard to have one there unless there was a bracket that extended out.
Definitely worth saving if it is a SSP. Black dash would need to be replaced anyway (cut holes) so it's not like it had a perfect interior before the black.
Old 09-08-2012, 05:07 PM
Just noticed the shock towers are white, there also appears to be some kind of rocker switch under the radio pointed at the console. Who used white/tan automatics? Oregon?
Old 09-08-2012, 06:01 PM
Haven't yet seen a CHP with an auto but some did have tan interiors in '84, '85, and '86. Haven't yet seen one with 9L paint though.
Only four-eyed with 9L paint and AOD trans that I'm aware of is HERE. There were two so far in the aero. One each in '89 from Georgia and Texas.
Old 09-08-2012, 06:12 PM
HERE is an '85 Utah white/tan but it's a manual.
Old 09-08-2012, 07:08 PM
ssp5.0 ssp5.0 is offline
Default "All original parts" !!
Never have seen an '85 with an Aero nose? Weren't they all 4 eyed?
Old 09-08-2012, 07:27 PM
Yes, that has been converted to aero.
Old 09-08-2012, 08:26 PM
1997ISPB4C 1997ISPB4C is offline
I maybe wrong here but i thought Automatics came with the big brake peddle? Maybe it was a 5 spd?
