Old 04-25-2012, 08:58 PM
Default 86 running real bad !!
Bought the 86 ISP in Feb 2004. Since that time it has had about 200 miles put on it and the fuel pump gave out a couple years ago and it has sat. This week I dropped the tank and put in a new fuel pump, new fuel filter, fresh fuel with seafoam. Car runs like total CRAP ! I put on an NOS IAC valve, cleaned the rotor button and distributor crap real well and it still runs like CRAP ! Hard hard hard to start then have to constantly pump the accelerator to keep it running. Pulled a couple of plugs and they are pretty nasty. Tomorrow I am replacing the plugs, rotor button and cap and if it still runs like CRAP ! I am going to replace all the injectors. Not sure what else I can do...... I also put in a brand new battery because the one it had in it died about 5 years ago.
Old 04-25-2012, 09:15 PM
smunczen's Avatar
smunczen smunczen is offline
Sounds to me like a bad computer do you have a spare?
82 CHP Unit#870366
86 TX DPS M6-380
Old 04-25-2012, 10:45 PM
calimustang's Avatar
ouch i feel your pain! did you check to see any rust in gas tank? that's what happened to me with my 89 SSP after not running for 7-8 years, rust was all over so i dumped the tank and got a new one, never had a problem ever since.
Michael J nicknamed as "MJ"
Proud owner of the vehicles:
1990 FHP unit - SOLD
2014 VW Jetta SportWagen TDI
Old 04-25-2012, 11:25 PM
EXNODRAMANOTCH's Avatar
Replace the fuel pump relay under the passenger seat. I had the same symptoms on my 86 GT convert 15 years ago (24k miles) when driving the car on my honeymoon (had to leave the car at Ford dealer half way to our destination and get it on the way home).
1979 2.3 Turbo Pace Car
1989 5.0 LX Convertible
Old 04-26-2012, 09:36 AM
chism's Avatar
chism chism is offline
Check the IAC (idle air control) valve. This and the 10 pin connectors on the back of the EGR plate are common problems for idle issues.
J. Chism
1989 Mustang LX 5.0, 5 speed (ex-TX DPS car)
#200882 unit# M9166- SOLD
Old 04-27-2012, 09:14 PM
really? can you post up a pic of that connector? mine almost have perfect idle but just a tad off and annoying because voltage gauge kept rocking at idle but driving is fine. no vacuum leaks or anything.
Old 04-27-2012, 11:25 PM
no rust in the tank
tried 4 different IAC valves today, no help
new plugs, cap, rotor button today. no help
Fuel pump relay is operating correctly.
it starts as soon as you crank it, tries to idle but acts like it is running out of fuel.
I believe the injectors are gummed up from sitting and bad fuel. Also the plenum has a screw broke off in it and a previous owner removed the factory finish on it and the valve covers. Tomorrow I am going to swap out injectors, plenum, and valve covers that I have on the shelf. Also going to replace a couple of dry rotted vacume lines. Hopefully these items will fix the issue.
Old 04-28-2012, 01:04 AM
Sal's Avatar
Sal Sal is offline
Vacuum leaks will cause the car to idle rough, and depending on the severity of the leaks can also cause it to stall. You've mentioned rotten vacuum lines...that's where I would start.
Old 04-28-2012, 03:47 AM
92NM-SSP's Avatar
92NM-SSP 92NM-SSP is offline
Default bad coil
sounds like the problem I had recently on my 86,,,it turned out to be a bad coil,,the car ran real bad and seemed like it was running out of gas,,replaced the coil and runs great
Old 04-28-2012, 08:10 AM
coil? hmmm.... I have a couple of spares lying around. I will try that also. thanks
