Restoration-related Equipment Tech Any questions or information about any period-correct resto equipment (ie. switchboxes, lights, radios). |
Thread Tools | Display Modes |
I am getting ready to hook up the whelen edge on my NV car.
I have a 3 switch Unitrol 480 i am using with it. The bar is a 8 strobe piece with takedowns and amber rear flashers. The inner strobes flash front and rear -outer strobes flash front and rear and there is an action cycle that makes all the strobes flash in pattern. What would be the best way to run the patterns on each switch selection? I also have my wig wag headlights i am hooking into the light controller also. Thanks |
My last marked car had a PCC9. 1 was rear flashers, 2 was the whole bar, 3 was the bar and siren.
http://www.whelen.com/_AUTOMOTIVE/install/133/13315.pdf
Mike '82 SSP (Marketing Order) '83 Colorado State Patrol #202 '83 Texas DPS '85 Florida Highway Patrol #1422 '93 Florida Highway Patrol #1187 '93 Florida Highway Patrol #1363 |
Thank you!
No prob.
I agree with Mike stage one is only the rear lights. Stage two is front and rear and out here stage three is all the lights if you have alley light those also. However, the siren is set manually and to the horn to change the tones. Good luck.
![]() Quote:
The siren on 3 was convenient since you didn't have to fiddle around with the buttons. It was just on, and you could use the steering wheel to cycle between tones when you needed to, like you described. You killed it by going back to 2.
I was going to do rear flashers stage 1
front and rear strobes with action flash stage 2 all above with takedowns and siren at stage 3 what stage for headlight wig wags? Also I am thinking of not hooking the alleys up? its a show car so thinking having every light lit on switch 3 might look ridiculous or is that how the PD's do it? I still didnt even get a siren yet for the car. |
![]() Quote:
Good enough. The unitrol doesnt have any extra switches so I will probably not hook up the alleys and takedowns.
Post pics when you get it installed...
Mike 1991 Pensacola PD (DSO 24-0349) Specs: Cop motor, cop tires, cop suspension, cop shocks and runs on regular gas |
