Old 02-09-2010, 03:57 AM
Theseeker152 Theseeker152 is offline
Default Hesitating
I have a 1988 Ex-WSP SSP......I have over 210,000 miles on it. I just had the Fuels injectors replaced, a new fuel regulator, Changed the Intake AirCharge Sensor(It was Very nasty looking), and Cap & Rotor.
When I try to accelerate it still hesitates. It's worse going up hill. There is more power than there has been, but the hesitating is driving me nuts!...If I light foot the gas pedal it does fine except up hill.
Any Help?...
Old 02-09-2010, 12:21 PM
timing issue? or fuel?
Old 02-09-2010, 02:26 PM
Also check your exhaust system. You may have a blocked or damaged cat(s).
Old 02-09-2010, 04:52 PM
Gearhead Gearhead is offline
Did you change the fuel filter ?? Might be clogged up if it hasn't been changed regularly....
Scott
89 NE SSP
03 Cobra
93 LX Hatchback
10 F250 SuperDuty
12 Boss 302
12 GT500
Old 02-09-2010, 07:40 PM
smunczen's Avatar
smunczen smunczen is offline
Check TIF module.
82 CHP Unit#870366
86 TX DPS M6-380
Old 02-09-2010, 09:44 PM
Fuel Fliter has been replaced, and is chaged twice a year.
Old 02-09-2010, 09:53 PM
TFI went out a few years back. It was replaced...Might have to change it again.
Old 02-09-2010, 10:29 PM
Thumbs up
check how the plug wires are placed on dist cap , lots of people don't know the HO firing order is like a 351w not a regular 302..
do you have a check eng light on ??
if this stuff checks out good , unplug 1 inj at a time , kinda like a power balance test .
your bad cyl will show no rpm drop when you do the inj test .
let us know your findings .
hector
Old 02-10-2010, 01:25 AM
I clocked the plugs wires on the cap to the correct the 5.0 clocking. It has brand new Motorsport 19LBS Injectors, and Fuel Regulator.
There is no check Engine light. It just surges/hesitates under somewhat hard acceleration, and up hills. a light foot on the pedal it is fine.
Old 02-10-2010, 09:38 AM
Thumbs up
see if you can fit a manual fuel gauge to the rail , then place the car under a load and see if the psy drops off ??? like a faulty fuel pump ?
if there is enough hose tape the gauge to the windshield and find that hill as your load , sounds like a junk pump my friend ?
your psi should stay 30-40 psi at all times .
hope this helps
I'm in tx but may be able to help over the phone ??
Hector 956/802-2983
