Old 01-22-2010, 02:07 AM
Theseeker152 Theseeker152 is offline
Default Correct Oil Filter
Does anyone know the Correct Oil Fliter For a 1988 SSP?.....I have a Ex-Washington State Patrol car. And nobody knows what the correct oil filter is for this year with an Oil Cooler.
I bought it and it had a Fram PH16 on it. I know this is the incorrect Filter.
I have heard anything from a Fram PH8, PH16, MotorCraft FL1, FL300, and K&N FH2004.....
Please any Help out there.
Old 01-22-2010, 09:11 AM
Unmrkd's Avatar
Unmrkd Unmrkd is offline
Resident Geezer
The Motorcraft FL 300 is the "Correct" filter. Other brands are available and any good auto parts store has a cross reference guide to show which ones fit with like size to the FL 300.
Gregg
'89 FHP Unit # 435 (Deceased)
Old 01-22-2010, 11:24 AM
+1 it is the FL-300
Old 01-22-2010, 10:40 PM
Fram would be the PH8. I don't know how it could have had a PH16 fit on top of the oil cooler. I had the mistake of trying to fit that one on my '93 SSP. I just forgot that it had the smaller one when I bought oil filters for the SSP and my '90 LX 'vert. I had just finished changing the oil in the 'vert and moved on the the SSP. Banging my head as to why this PH16 oil filter wouldn't fit! Then I came to my senses...
Old 01-23-2010, 12:35 AM
Default PH8
A PH8 is too long due to the Clearance between the Oil Cooler and Sway Bar, PH 16 gives the right clearance.
I at first tried the PH8 but it wouldn't fit, or even start to spin on. So, I assumed that's why they used the 16...I did too...Thanks for the info.
Old 01-23-2010, 03:22 PM
FHP0827's Avatar
FHP0827 FHP0827 is offline
Use the Motorcraft filters, FL-300 if you are running the oil cooler. Fram filters are JUNK and can and will cost you a engine.
Self-proclaimed FHP SSP guru
Old 01-24-2010, 10:08 AM
Did I say that backwards? The 16 is the short and the 8 long?
Old 10-26-2025, 03:17 PM
BannysSSP BannysSSP is offline
My 87 WSP SSP has PH43 written in marker on the radiator support. I am assuming the fleet mechanics put it there for a reference.
