Old 10-25-2009, 05:00 PM
Winterpark SSP's Avatar
Alibi
Default 1993 Winterpark SSP: Pic's on updates :)
SSP_8.JPGHey guys! I wanted to keep you posted on a few changes I made to the Winterpark SSP.
1) Unity Spotlight went from chrome to black (sorry Marco).
2) Winter Park Police Original "Hat" badge (amazing what is on ebay sometimes)
3) I added a Federal Signal interior "Little Lite" (Model LF12TR)
4) WPD 1017 Custom License Plate
I know I have debated selling this car before...but I love this darn thing!!!
Anyway, the beauty of not having a CHP or FHP in this case is I can deviate a "little" from the norm (tastefully of course) as there is no true "standard" on which the WPD cars were outfitted. I must admit though, it is 90% the way WPD had it while in service. The only cosmetic items really not "on point" are the Black Spotlight (original Chrome), Rear Deck Lights (original Round PAR 36 Strobes) and "black" 10-Hole Wheels. (probably the "FS" Little Light also).
I hope everyone is doing well.
Barry
"Future Is What Present Does"
Collectables:
Other(s):
1995 Corvette ZR1 (859 miles)
"Kiddie Carrier"
Old 10-25-2009, 06:02 PM
CHP8336's Avatar
CHP8336 CHP8336 is offline
1985 CHP/NEV SSP'S
Very nice car!!! You did a GREAT job on restoring it. I think your car is set up perfect..........Rich
[SIGPIC][/SIGPIC]
1985 California Highway Patrol #8336 Napa Ca office.
1985 Nevada Highway Patrol #30. Federal Test Car. Reno Nv office.
California Highway Patrol#8336 & Nevada Highway Patrol #30 Restoration Pictures.
http://public.fotki.com/CHP8336/
Old 10-25-2009, 06:21 PM
Alibi
Default Thanks!
THANK YOU!
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 10-25-2009, 07:06 PM
Barry - Awesome looking car...thanks for posting your pictures.
Old 10-26-2009, 08:11 PM
Talking
Looks great. I would have never known anything was not as it was originally.
Old 10-26-2009, 11:46 PM
Charlie's Avatar
Charlie Charlie is offline
I like the black spotlite, even if its not original
1970 Dodge Sweptline pickup
1991 Ford Bronco "Nite Edition"
Still hoping to find a Connecticut SSP
Old 10-27-2009, 07:43 AM
Alibi
Default Rear Light Flashers
I forgot to mention I installed a Galls tailight flasher. It alternates the turn and reverse lights. Looks great.
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 10-27-2009, 08:30 AM
Alibi
Post Updated Restoration List: It keeps growing :)
1993 Winterpark Florida SSP (72K Miles)
Restoration List
Year: Agency: Unit #: Tag #: Last 6 VIN: DSO: Color code:
1993 Winter Park, FL PD 1017 147059 27-0409 WB
**Vehicle trunk lid sighed by Jack Rousch!”
• Synthetic Oil Change
• Rear End Fluid Change
• Brake Fluid Flush
• Power Steering Fluid Flush
• Antifreeze Flush
• 134A A/C Charge
• Spark Plugs/PCV Valve/ Air Filter/Spark Plug Wires/Fuel Filter
• Distributor Cap and Rotor
• ICM (Ignition Control Module)
• Oxygen Sensor(s)
• Serpentine Belt
• Stabilizer Bar Links/Bushings
• Steering Rack Boot(s)
• Coolant Overflow Bottle
• 130 amp alternator
• Rear Shocks
• Emission/Smog Pump
• Factory H-Pipe
• All vacuum hoses including vacuum harness
• Valve Cover, Plenum and Throttle Body gasket(s)
• 4 Wheel Alignment and Wheel Balancing
Engine Bay: (100 + Hours)
• New Air Box and Fender Studs
• Polished 5.0 Plenum Plate
• Oil Cap
• Power Steering Cap
• Radiator Cap
• Hood Stops
• Powder Coating:
o Valve Covers; Plenum; Throttle Body; Mass Air Flow Sensor; A/C Compressor Bracket; Power Steering Pump; Smog Pump; Charcoal Canister; Hood Latch, Radiator, Transmission Cooler and Pulleys.
o Cleaning: Underside of hood, all nuts/bolts, sheet metal, firewall etc.
Undercarriage: (60 Hours)•
Cleaning:
o Undercarriage covered in high strength all purpose cleaner and pressure washed with hot water to remove all dirt and debris.
o Wheels removed and cleaned and polished inside and out.
o All suspension parts sanded and coated with “POR 15” to original factory specs.
o Calipers/Brake Drums/Brake Lines Painted
o Driveshaft sanded and coated with” POR15”.
o Sway bars removed and powder coated.
o Exhaust wet sanded with 600 and 2000 grit sandpaper and polished to new finish.
o There is not a spec of dirt or grease on the undercarriage. Everything polished and highly detailed.
Exterior:
• Wet Sand entire car with 2000 grit paper
• Compound then Glaze with high speed buffer to mirror finish
• “Dent Wizard” (Paintless Dent Removal) removed all door dings, etc.
• Apply original “Winterpark Police” decals and stripes
• Front and Rear bumper covers removed from vehicle and painted
• Body side moldings removed and painted
• Roof holes patched and roof painted.
• New “Ford” front bumper cover emblem
• New Cowl Grill
• New Centercap(s)
• 5.0 Interceptor and “LX” trunk emblems
• OEM Headlamps/Marker Lamps/Parking Lamps
• Satin Black Powder Coated 10-Hole Rims (including spare)
Interior:
• Brake Pedal
• Factory OEM Floor Mats
• Interior Carpet
• Trunk Carpet
• Interior Floor Console
• Speakers
• Shifter Trim Plate
• Door Map Pockets
• Front Seats-reupholstered
• Package Tray (rear deck)
• Window Tint
• “Big Sky” Trunk Mounted Shot-Gun Rack
Electronics:
• Whelen Dash Master Deck Strobes
• Whelen 75W Strobe Power Pack (upgraded from 25 watt)
• Whelen “Hide Away Strobes” in taillights and side marker lights.
• New Federal Signal PA300 Siren (upgrade from PA200)
• New Federal Signal “Little Lite” for interior.
• Motorola Spectra UHF Mobile Radio and Speaker
• Galls Headlight (Wig-Wag) Flasher/3x per second
• Galls Tailight Flasher (alternating signal and reverse lights)
• 4” 800mghz Trunk Antenna
• Federal Signal “JetStrobe” Lightbar (10 strobes/alley lights/takedowns)
• Custom bracket fabricated for Lightbar Controller replacing cassette pocket below radio.
• Custom shelf for trunk mounted radio base and strobe power pack(s).
Miscellaneous
• Reproduction Window Sticker
• California Black Custom Car Cover (will fit light bar and spotlight)
• Custom WPD 1017 License Plate
• WPD Hat with Badge; T-Shirt; Sweater; Baseball Cap; etc.
Performance
(Wanted to keep factory with hidden/tasteful performance mod’s that can be turned back to original)
• B&M Transmission Shift Kit (mild)
• Ford Racing Headers (non-ceramic to look exactly like factory)
• 3.55 rear gears (Installed by Winterpark PD)
Collectables
• 1993 Ford ABS Police VHS Tape
• 1:18 Scale Mustang New York State SSP
• 1993 Ford Mustang Brochure
• 1993 Ford Mustang Police Interceptor Brochure
• 1993 SSP Supplement
• 1993 Ford Mustang SSP Order Form
• 1993 Ford Crown Victoria Police Interceptor Brochure
• 1993 Ford Taurus Police Interceptor Brochure
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 01-01-2010, 08:18 PM
Default eBay Posting
Here's a link to Barry's listing I noted today on eBay...
http://cgi.ebay.com/ebaymotors/Ford-...fCarsQ5fTrucks
Wishing you well on the auction Barry.
