Go Back   Special Service Mustang.net Forums > Special Service Mustangs/Parts Wanted
Special Service Mustangs/Parts Wanted Cars and Parts wanted here.
Old 08-17-2009, 05:36 PM
Winterpark SSP's Avatar
Alibi
Question WTB: Taillight Flasher (reverse lights)
Does anyone have or know where I can purchase a taillight flasher?
Reverse Lights or Reverse and Turn Signal.
THANK YOU!!!
Barry
"Future Is What Present Does"
Collectables:
Other(s):
1995 Corvette ZR1 (859 miles)
"Kiddie Carrier"
Old 08-17-2009, 08:25 PM
Try elightbars.org....should have no problem finding one there.
Old 08-17-2009, 08:50 PM
Alibi
Smile Thank You!!
Thanks for the quick reply
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 08-19-2009, 08:14 PM
Alibi
Question Specific Products ?
Hey Guys,
I keep seeing this "warning" with the taillight flashers. Any specific model that works with our cars?
THANK YOU!!!!!
II. INSTALLATION.
WARNING
DO NOT connect flasher to brake light circuit of FORD
vehicles.
Ford Motor Company technical service bulletins TSB 99-
09-10 and TSB 99-13-09 advises against modifying the
brake circuit (Circuit 511) or any electrical interface with
brake lamps. Connection of aftermarket electrical
equipment into this circuit may interfere with the brake
shift interlock.
This could cause the vehicle to unexpectedly move
forward causing possible property damage, injury or
death to the vehicle operator or others
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 08-19-2009, 09:04 PM
You should be OK...there were some issues with Crown Vics and shift interlocks being disabled.
Old 08-22-2009, 12:36 AM
Alibi
Default Thanks Again!
I will order this week
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 08-27-2009, 02:04 PM
TxDps TxDps is offline
Remember the correct wire coloring in the trunk!
I hooked mine up years ago, in the dark and in a hurry.
Tried it out and all I heard was a hum on, hum off, hum on, hum off.
??? Sounded like the fuel pump.
Sure enough, there is a pink with black wire, and a black with pink wire.
So much for being in a hurry the night before an event!
-Tony
-1988 Ex Tx DPS SSP
-1984 Ex Tx DPS SSP
-2003 Ex Tx DPS Crown Vic
-1993 Cobra
-1978 Mustang II
-MCA - Regional Director - #26240 - Since 1991
Old 08-27-2009, 08:05 PM
Alibi
Default Thanks!
I would easily make that mistake!
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 09-20-2009, 08:19 PM
Alibi
Default Brand
Which Brand and Model did you use? Was it reverse or reverse and signal flasher? THANK YOU!!
Barry
Collectables:
Other(s):
"Kiddie Carrier"
Old 09-22-2009, 03:18 PM
mustangretriever's Avatar
mustangretriever mustangretriever is offline
You can wire in a regular headlight flasher too if it's done properly. If your car is a maunal then then there is no concern regarding the auto transmission shift interlock. However, the warning given for flashing taillights applies to all Fords with an auto transmission, Crown Vic, Mustang, Trucks, etc. What flashing the tailights can do is disable the vehicles shift interlock, basically you can shift the car out of park without depressing the brake when the flasher is on. It's more of a CYA thing for Ford and the maker of the flasher, it's not like the vehicle will spontaneously shift itself out of park and drive off like KITT could do!
Eric
1989 Missouri State Highway Patrol SSP Mustang - P294
www.fotki.com/mustangretriever
