Old 02-19-2007, 10:19 PM
bmt336's Avatar
bmt336 bmt336 is offline
Supreme Allied Commander
Default door hinge pins
ok, the green fhp has the original door hinge pins on the pass door, which is sagging. How do you get the originals out so the replacements will go in? they seem to have been pressed in, can it be done without removing the entire door. The driver door had already had the bottom one done, so it was easy to replace.
Also put in new door to body weatherstrip today.
Bret
1967 Thunderbird 4 dr Landau
1971 Chevrolet BelAir 18000 org miles
2002 Crown Vic Sport
Old 02-19-2007, 11:11 PM
They are pinned in there....kinda hard to remove, as you have to grind them down a bit to knock them out.
Old 02-19-2007, 11:21 PM
bmt336's Avatar
so dremel tool is good?
Bret
Old 02-19-2007, 11:35 PM
Air, if you have it. It's halfway-serious grinding.
Old 02-19-2007, 11:59 PM
bmt336's Avatar
yea, Frank has a compressor in the shop. Thanks
Bret
Old 02-21-2007, 11:01 PM
bmt336's Avatar
yea, this was the biggest pita of anything on this car. But it is done and the doors line up real well.
Bret
Old 02-21-2007, 11:10 PM
You did it already? Good deal.
Old 02-22-2007, 12:12 PM
svopaul's Avatar
svopaul svopaul is offline
The White Fred Sanford
You are already done but I just cut the pin in the middle and then remove both pieces...much easier than trying to get the whole pin out.
