Old 07-14-2009, 09:04 AM
Winterpark SSP's Avatar
Alibi
Default 1993 Winterpark SSP: FOR SALE
:Wow
I am selling the1993 Mustang SSP from Winterpark Florida. Those of you that have been members here for some time are familiar with my restoration, specifically my attention literally to every detail. I have spared NO expense and have well over $24,000.00 invested in this vehicle.
What is unique about this vehicle is that it has low "in service" miles, has never seen any elements (e.g.snow/salt) and is an absolute perfect, turn key SSP that is "in the wrapper". Also, the truck lid was signed by Jack Rousche!!
If you are interested, please email me at beterginio@yahoo.com or call me direct at (860)919-8999. I am in no rush to sell and am looking for serious offers from buyer who can appreciate all the time and money invested. Thank you for looking!
Here is the master list of what was completed:
1993 Winterpark Florida SSP (72K Miles)
Restoration List
Year: Agency: Unit #: Tag #: Last 6 VIN: DSO: Color code: Owner:
1993 Winter Park, FL PD 1017 147059 27-0409 WB
**Vehicle trunk lid sighed by Jack Rousch!”
•Synthetic Oil Change
•Rear End Fluid Change (with limited slip additive)
•Brake Fluid Flush
•Power Steering Fluid Flush
•Antifreeze Flush
•134A A/C Charge
•Spark Plugs/PCV Valve/ Air Filter/Spark Plug Wires/Fuel Filter
•Distributor Cap and Rotor
•ICM (Ignition Control Module)
•Oxygen Sensor(s)
•Serpentine Belt
•Stabilizer Bar End Links and Bushings
•Steering Rack Boot(s)
•Coolant Overflow Bottle
•130 amp alternator
•Rear Shocks
•Emission/Smog Pump
•Factory H-Pipe
•All vacuum hoses including vacuum harness
•Valve Cover, Plenum and Throttle Body gasket(s)
•4 Wheel Alignment and Wheel Balancing
Engine Bay: (100 + Hours)
•New Air Box and Fender Studs
•Polished 5.0 Plenum Plate
•Oil Cap
•Power Steering Cap
•Radiator Cap
•Hood Stops
Powder Coating:
*Valve Covers; Plenum; Throttle Body; Mass Air Flow Sensor; A/C Compressor Bracket; Power Steering Pump; Smog Pump; Charcoal Canister; Hood Latch, Radiator, Transmission Cooler and Pulleys.
Cleaning:
*Underside of hood, all nuts/bolts, sheet metal, firewall etc.
Undercarriage: (60 Hours)
Cleaning:
oUndercarriage covered in high strength all purpose cleaner and pressure washed with hot water to remove all dirt and debris.
oWheels removed and cleaned and polished inside and out.
oAll suspension parts sanded and coated with “POR 15” to original factory specs.
oCalipers/Brake Drums/Brake Lines Painted
oDriveshaft sanded and coated with” POR15”.
oSway bars removed and powder coated.
oExhaust wet sanded with 600 and 2000 grit sandpaper and polished to new finish.
oThere is not a spec of dirt or grease on the undercarriage! Everything polished and highly detailed!
Exterior:
•Wet Sand entire car with 2000 grit paper
•Compound then Glaze with high speed buffer to mirror finish
•“Dent Wizard” (Paintless Dent Removal) removed all door dings, etc.
•Apply original “Winterpark Police” decals and stripes
•Front and Rear bumper covers removed from vehicle and painted
•Body side moldings removed and painted
•Roof holes patched and roof painted.
•New “Ford” front bumper cover emblem
•New Cowl Grill
•New Centercap(s)
•5.0 Interceptor and “LX” trunk emblems
•OEM Headlamps/Marker Lamps/Parking Lamps
•Satin Black Powder Coated 10-Hole Rims (including spare)
Interior:
•Brake Pedal
•Factory OEM Floor Mats
•Interior Carpet
•Trunk Carpet
•Interior Floor Console
•Speakers
•Shifter Trim Plate
•Door Map Pockets
•Front Seats-reupholstered
•Package Tray (rear deck)
•Window Tint (lightest available; exact film Winterpark PD utilized)
•“Big Sky” Trunk Mounted Shot-Gun Rack
Seat Organizer: Complete with ticket holder, “Billy” club and Handcuffs.
Electronics:
•Whelen Dash Master Deck Strobes
•Whelen 75W Strobe Power Pack (upgraded from 25 watt)
•Whelen “Hide Away Strobes” in taillights and side marker lights.
•New Federal Signal PA300 Siren (upgrade from PA200)
•Motorola Spectra UHF Mobile Radio and Speaker
•Galls Headlight (Wig-Wag) Flasher/3x per second
•4” 800mghz Trunk Antenna
•Federal Signal “JetStrobe” Lightbar (10 strobes/alley lights/takedowns)
•Custom bracket fabricated for Lightbar Controller replacing cassette pocket below radio.
•Custom shelf for trunk mounted radio base and strobe power pack(s).
Miscellaneous
•Reproduction Window Sticker
•California "Black" Custom Car Cover (will fit light bar and spotlight)
Performance
(Wanted to keep factory with hidden/tasteful performance mod’s that can be turned back to original)
•B&M Transmission Shift Kit
•Ford Racing Headers (non-ceramic to look exactly like factory)
•3.55 rear gears (Installed by Winterpark PD)
Collectables
•1993 Ford ABS Police VHS Tape
•1:18 Scale Mustang New York State SSP
•1993 Ford Mustang Brochure
•1993 Ford Mustang Police Interceptor Brochure
•1993 SSP Supplement
•1993 Ford Mustang SSP Order Form
•1993 Ford Crown Victoria Police Interceptor Brochure
•1993 Ford Taurus Police Interceptor Brochure
Barry
"Future Is What Present Does"
Collectables:
Other(s):
1995 Corvette ZR1 (859 miles)
"Kiddie Carrier"
