Old 05-27-2009, 04:19 PM
Default WTB - CHP Whip Clip
I'm planning ahead. I saw the following thread about whip clips for the CHP cars -
http://www.specialservicemustang.net...ead.php?t=1180
So does anybody have a spare clip and/or bracket? I figure that I can buy a sheet of the correct material to replicate one, but I'm not sure what the correct thickness is. Any help would be appreciated.
EDIT: I need to find the proper length antenna too
Old 05-28-2009, 11:35 AM
Andy Andy is offline
I still need the whip clip for my car!
with regard to the low band whip antenna
the problem is finding the correct antenna (correct length)
with the tip Ball / Static Ball as a solid single unit.
I had to cut down a 102 in. CB stainless whip antenna
and create a TIP to lock into the Home made whip clip
as seen in your link/post.
also look here
http://specialservicemustang.net/for...&highlight=468
Old 05-28-2009, 01:27 PM
also look here
So Andy, how long is yours?
EDIT: Let me rephrase that - What length did you cut your whip antenna to?
Last edited by 28HopUp; 05-28-2009 at 01:27 PM. Reason: It just didn't sound right :-P
Old 05-28-2009, 02:03 PM
Talking
Oh my! Another Obama supporter
Old 05-28-2009, 04:50 PM
Don't make me delete this thread young man...
Old 05-28-2009, 04:54 PM
Using this calculator:
http://www.crompton.com/wa3dsp/hamradio/antcalc.html
set for 42.5 Mhz yields approx. 66" length for the whip. I bought an ASP 96" whip and cut it down at the opposite end from the tip. If you use a hacksaw, be sure the blade is for stainless steel.
Old 05-29-2009, 12:10 AM
Old 05-29-2009, 01:16 AM
The ASP-121 whip is not threaded. It comes with and fits into an adapter (held by a set screw) which is threaded to fit into the top of the ASP-570 spring. It all works together with the ASP=3 ball mount and is what is correct for use on a CHP car.
See the product tech sheets for all these parts here:
http://public.fotki.com/Classicchp/s...ang_technical/
Old 05-29-2009, 09:05 AM
I realize that this is turning from a WTP thread into a technical post, but I'd like to ask for some clarification.
http://www.specialservicemustang.net/CHP2.htm
The above link says that the whip was 96" in length, yet it was posted in this thread that the correct length was calcualted to be roughly 66". Which is it?
I received an authentic CHP whip antenna that was roughly 66" in length (mailed to me from California with a shipping label folded around the shaft like a flag at half-mast). However, I really don't see how a 66" long antenna would reach the clip by the doorjam. Was the shorter antenna used without clipping it into the doorjam?
Again, there seems to be conflicting infomation - just seeking wise counsel here boys!
Old 05-29-2009, 09:35 AM
Bill,
You are correct. It's a typo. The replacement whip is 96 inches in length, and has to be cut to fit.
Mike C.,
If it's OK with you, when I fix the above in the Resto Doc, I'd like to post the brochure pic that you put into the thread.
