Old 01-15-2009, 10:19 PM
stubes stubes is offline
Default FHP jetsonic lightbars
i recently and purchased an original fhp lightbar for my 91 resto.
when i opened it, the rotators were turning very very slow, but i attribute that to the bar sitting out in almost 0 degree temps on my porch all day.
after a few hours of letting it warm up i tested it. everything works great.
i have nos domes for it, a speaker and after some TLC it will be like new.
i have some questions about how it is suppossed to work regarding the florida light patten.
it has the relay circuit board with the three drum things on it......
when i touch the red and red/white wires to power all 4 lights rotate.
when i touch the red and blue white wires all four rotators flash but don't turn
when i touch the red/red white and black white wires all 4 lights rotate but only 2 rears light up
when the blue/white wire is touched to power itself the two rear copper things click
when the black/white wire is touched to power itself the front copper thing clicks..
same for the red/white itself makes the relay things click..
any ideas? and if i happen to need the fhp style circuit board, anyone have a spare?
thanks
Old 01-15-2009, 11:53 PM
please see pics
also:
next to the motor there is a white plug that appears it should be plugged into something but is not.
any ideas?
Old 01-16-2009, 12:58 AM
i think i have everything figured out.
regarding the fhp pattern-can work in following ways
all 4 lights turn and work just as rotators:
or
all 4 rotators go to the same position and work as flashers:
or
all four rotators turn with only rear lights working
outboard takedowns
alleys
sound correct? if so i am good to go.
Old 01-16-2009, 07:10 PM
or
or
outboard takedowns
alleys
Sorry...I've been busy at work and haven't been able to get on here.
You have a front light cutout feature, which is a separate function. In other words:
1)all rotators turn and are on; or
2)all rotators park and then flash; or
3)all rotators turn, only rears are on (*with front light cutout activated); or
4)all rotators park and only rears flash (*with front light cutout activated)
Old 01-16-2009, 08:37 PM
yep i got the lightbar doing those seperate functions.
all i have left is to find a JSS and will have all the correct equipment for my car
i got confused thinking the lights were suppossed to rotate and then flash in the same sequence but thats not possible.
