Old 01-10-2008, 11:50 AM
Unmrkd's Avatar
Unmrkd Unmrkd is offline
Resident Geezer
Originally Posted by mustangretriever View Post
I like that dash! What'd they have installed in there...a VCR?!
Eric, you should have seen it - it was the switch panel from hell!! The console ash tray lid was also converted to switches. If you turned them all on at once the alternator would have self distructed.
All of it very creative but easy to remove and Jim will replace the dash and console and this will be only a distant memory.
Gregg
'89 FHP Unit # 435 (Deceased)
Old 01-10-2008, 01:04 PM
calimustang's Avatar
Oh yes tell me about it, thats why i let Jim have it instead of me.
Originally Posted by Unmrkd View Post
Jim didn't mention the special SSP fog lights, "Square" spotlight, hanging in the breeze driver's tail pipe and "SUN" tach on the steering column. It never ceases to amaze me what some people do to these cars.
Having said all that - the car is really straight and all the panels have the tags on them. All the engine harnesses/vaccume lines etc are there. It was a good save and will be a beautiful car when completed. You have to have the ability to look beyond the present condition and see the potential to do this hobby.
Originally Posted by mac88chp
Very nice addition Jim, I've always liked the '87-'89 cars the best for their black wheels, interiors and performance and they look great in FHP livery too. This is the car MJ located, right?
Yes, this is the one i found.
Michael J nicknamed as "MJ"
Proud owner of the vehicles:
1990 FHP unit - SOLD
2014 VW Jetta SportWagen TDI
Old 01-10-2008, 04:52 PM
The car still had strobes in the corners with all the wiring and switch panels. I found a wig-wag box in the front and rear plus about 15 pounds of wire under the dash to power everything. THANK GOD !! the mice ate the strobe wiring and not the original ford harnesses.
the mouse nest was under the rear passenger seat and about the size of a basketball.......and you can imagine the smell !!
Gregg....you were right about the ignition. When I removed the sun tach to preserve for you since it is from back when you were only 50 years old (1977).....I found the ignition module thingy you were talking about was in pieces. Hopefully I can replace it and then put in some fresh fuel and fire her up ?????
Old 01-10-2008, 11:31 PM
Gregg,
You look damn good for 81
Old 01-10-2008, 11:37 PM
Unmrkd's Avatar
Resident Geezer
it is from back when you were only 50 years old (1977).....???
Just for that I hope the mice ate your build sheet!
The ignition switch is still available from Ford somewhere around $22. Let us know how it goes with fireing it up. Keep an eye on that fan to waterpump coupler.
Gregg
Old 01-11-2008, 02:17 AM
Oh yes i remember finding the strobes and saw some wirings attached to it but couldn't trace it to where it goes, possibly because of mice ate it up as you mentioned, now it makes sense. 15 lbs worth of wiring? thats A LOT! Did you test the switch panels? Also are you going to keep the strobes in it?
Old 01-11-2008, 11:39 AM
i threw all the strobes, wiring,, etc. in the garbage. I kept the big switch box as I might need a switch or two in the future for something else. FHP did not run strobes in the corners of their mustangs so it will not be restored with them.
Old 01-11-2008, 12:57 PM
Ah ok.. i knew they didnt run strobes unless the trooper adds it himself which is very few.
