Old 09-08-2012, 11:19 PM
Both the pedals on the fox are small whether stick or aod.
Old 09-09-2012, 09:05 AM
The AOD brake pedal pad is larger and a different shape than the manual brake pedal pad. (See attached images.)
The manual brake pedal pad and the clutch pedal pad are the same. They're just 180º out-of-phase from each other.
Old 09-09-2012, 09:49 AM
You learn something new every day.
Old 09-09-2012, 09:32 PM
1997ISPB4C 1997ISPB4C is offline
Well to me it looks like the manual peddle and not the auto anybody else?
Old 09-09-2012, 09:37 PM
Looks like a worn auto pedal pad. The manual has empty space on both sides of the "lines".
Old 09-09-2012, 11:14 PM
It's an auto pedal. Manual pedals are probably 1/4 smaller width wise.
Old 09-12-2012, 10:38 PM
sspanthony's Avatar
sspanthony sspanthony is offline
Mustangoholic
Well things are starting to add up now ! When I looked at the engine pic, ( next to last pic at bottom row ), I couldn't help but notice the row of solenoids mounted by the frame rail ? Then I looked at the breather lid that said " 4V H.O. and looked at the frame rail again ????
In 1985 there were no V8 4 barrel automatic cars produced; if the car was a 5.0. automatic, then it would have been CFI, (Central Fuel Injection), and would of had that row of solenoids that appear in the pic.
So my guess is that it is factory 5.0. automatic car with the wrong breather top on it...... just my 2 cents.
93 SCHP
92 FHP
MCA Member
Old 09-12-2012, 10:52 PM
Good eye on the solenoids. Didn't even think to look for details like that. Now I notice the distributor has a TFI module attached.
