Go Back   Special Service Mustang.net Forums > Welcome!
Welcome! New Member/Visitor area. Feel free to post up any questions you have about the site or the forums.
Old 03-29-2010, 09:19 AM
ABN2060's Avatar
ABN2060 ABN2060 is offline
Old 03-30-2010, 09:11 PM
You got that special tool to get those front springs out? I've heard they are very expensive!
Old 03-30-2010, 10:02 PM
CNTLOSE's Avatar
CNTLOSE CNTLOSE is offline
It is what it is.
No tool is needed. Use a jack to take the weight off the shock and sway bar...unbolt them. Use a small chain and secure the spring to the A arm then slowly let the jack down. To install new springs reverse the order. Also the higher you get the car the easier it is.
1990 NMSP Unit 130 SOLD
1989 WSP SOLD
1988 FHP SOLD
1991 FHP SOLD
1993 TX DPS
Old 03-31-2010, 01:41 PM
ABN2060's Avatar
No "special" tools needed to get it out. Like CNT said, chain the spring to the control arm just to keep it from flying out at you, lower the control arm and pry it out. The trick is getting it back in though.
Old 04-01-2010, 08:52 PM
Yeah, that's the trick. Getting it back in. And what a B*&^#H that was. I made my own special tool. A couple U bolts. Compressed the spring with a spring compressor rented from the local parts store. Hooked up the U bolts to keep the tension. Dropped the spring in place. Hooked up the strut. Let the U bolts off. Is what I finally came up with.
Old 04-01-2010, 09:55 PM
ABN2060's Avatar
My spring compressor is a piece of crap. Tried today to reinstall them and it looks like I will have to get innovative.
Old 04-29-2010, 12:47 PM
ABN2060's Avatar
Well, this took a couple steps back. In the process of lining up the hood and fenders, I discovered that the whole structural part of the front end was pushed over by 1 3/4" to the drivers side. I can only assume this happened when it crashed back in '95 and was not fixed properly. So, I dropped it off at a frame shop to have it fixed. It will be a week or two before I get it back but I'm sure it will be better than new after this guy gets done with it. This thing is going to be straight as an arrow.
