Old 03-02-2010, 08:49 PM
mustangretriever's Avatar
mustangretriever mustangretriever is offline
Originally Posted by MOstang View Post
Hector - I'm certainly not an expert on the CSP cars, but was thinking same as you were...shotgun rack. The MSHP in some instances had brackets they customized and installed in that general location within the SSP's. Hopefully someone else will be able to provide some solid info.
The MO door brackets were made for a PR-24. But some Troopers have told me they shoved their Remington 870's into them!
Eric
1989 Missouri State Highway Patrol SSP Mustang - P294
www.fotki.com/mustangretriever
Old 03-02-2010, 09:29 PM
That certainly makes sense.
Old 03-03-2010, 12:07 AM
Originally Posted by ssp91ssp View Post
Take a look at the mounting holes on driver's door of my CSP ...
It's got 5 mounting holes for something ???
I have seen pics of older ssp's that had a shotgun mounted there ???
my paper work states this car had a shotgun mounted .
any ideas ???? the length of the holes is too long for a club i think ??
it measures 28" from the 1st to last hole .
Mr Drama , is your driver panel on the CSP the same way ? any ideas ?
Hector,
The mounting holes on your door were for an in-house-fabbed shotgun shell holder. I know it sounds weird, but CSP screwed them into the door (webbed material with elastic for the shells). I have an email somewhere from the trooper that drove my '83 describing it, but I have no idea how long they were or how many shells they held. My '83, which is still original down to the paint, has the same holes in the door panel.
You should have several holes on the top of the rear driveshaft hump. This is where the shotgun rack was mounted. The shotguns were Remington 870s with folding stocks, and they were stored with the stocks folded up. The Trooper that drove my car described that as well, and I'm sure his memory was correct; he killed a suspect while driving my car with his shotgun.
Old 03-03-2010, 09:15 AM
Excellent info Mr. Evil.
Old 03-03-2010, 09:23 AM
Thumbs up
Hector,
You should have several holes on the top of the rear driveshaft hump. This is where the shotgun rack was mounted. The shotguns were Remington 870s with foldding stocks, and they were stored with the stocks folded up. The Trooper that drove my car described that as well, and I'm sure his memory was correct; he killed a suspect while driving my car with his shotgun.
Mike ,
Wow ! thanks for that info ..
I will raise my CSP at lunch time and check the trans tunnel for extra mounting holes .
Old 03-03-2010, 09:30 AM
Question shotgun mounting holes ???
Jim ,
Did you notice these mounting holes that Mike just mentioned at rear of trans tunnel while your interior was out ???
Old 03-03-2010, 09:35 AM
Yes I believe they are there. I will check for sure when I get back home on Friday evening.
Old 03-03-2010, 10:19 AM
Thumbs up shotgun mounting holes ???
Mr Evil,
Your the man ! I owe you a cold one friend ..
check out the pics .
these holes are at the rear trans tunnel just as Mr Evil said ..
thank you !
Old 03-03-2010, 10:24 AM
Thumbs up more equip mounting holes CSP
these as you can see are on the pass side of tunnel right next to
trans tailshaft ...
thanks to all again !
Old 03-03-2010, 04:52 PM
Congrats on finding those.
