Old 10-09-2011, 06:49 PM
Basically talking about the HD thermal flashers, 550 style...
...somewhere between 60 and 90 flashes per minute.
Old 10-09-2011, 06:56 PM
Here is my console Mike, if you've got the time. The two holes on the side I assume will be for the GE Mastr mic. The hole up front on the lower flat base that I'm not sure about, could that be the switch to run the lights? Is it just a metal toggle switch in your car, and where did they mount the flasher? There is one small hole at the back of the console, but it would be under the trim bezel so I'm not sure that it has any relevance. As always, your help is GREATLY appreciated!
Old 10-09-2011, 08:32 PM
And thank you for the flasher advice Greg and Mike. I'll start looking to source the correct one.
Old 10-09-2011, 10:17 PM
Found an actual SHO-Me unit which will do the trick and is a bit more reliable than just the thermal unit:
http://www.ebay.com/itm/130459519027...84.m1497.l2649
I got one for my deck lights on the ISP car.
Old 10-09-2011, 10:30 PM
I'll look for the pic of my console so you can see the differences. The switches are long gone; only the holes remain.
Old 10-10-2011, 10:02 AM
Greg, thank you very much for the flasher link! I'll order two today. Mike, I sure appreciate it. Let me know what you find and post the picture. When I get some time I intend to drop by the DPS motorpool with the car and see if there are any old-timers still around that might help also.
