Old 11-03-2008, 08:29 PM
The numbers were above the sticker on some, and below on others. Did you only check the top?
You just have to pull pretty good on the seat bottom (at the rear, where the lower cushion meets the upper, then up towards the front seats)....it's a friction fit. The rear seatback should have a couple of bolts holding it down, then it goes straight up.
Old 11-04-2008, 10:38 AM
I only checked above the door sticker. I'll try lifting the paint below it too and see if I can find anything looking like the remnants of painted numbers. Given how smooth the topcoat looks, I don't think I'll find anything underneath but we'll see.
Ahh, you yank from the back of the seat cushion! That made a big difference. Just as I suspected, the back seats are not original to the car either.
This SSP reminds me of an old hot rod, being cobbled together with parts from different cars:
  • The original 15x7 steel spare tire I have will not fit over the front hubs because the brakes have been upgraded. Paperwork from the seller says they are SVO brakes, but the hubs are 4-lug. So what brakes do I have that are larger than the stock 85 brakes?
  • The 8.8" rear-end with disc brakes also are said to be from an SVO, but they too are 4-lug. Judging by how the tires fit in the wheelwell, it doesn't appear to be the wider Turbo Coupe rear-end. So what 8.8" Fox rear came with disc brakes?
  • The front-end body work shows no signs of having a hole for a front speaker. May not be original to the car as a result of a prior accident (post-auction).
I know I'll find more "irregularities" as I dive deeper into the car. I'm by no means frustrated at all. It's all part of the car's past, and as the current owner it's my job to sort it all out.
Old 11-04-2008, 10:51 AM
predator20's Avatar
They are probably the '87 and up 11" brakes.
The rear disc 8.8, I'm not sure. I think you can get some rear disc swap out of a Lincoln. So maybe they are different from the turbo coupes. Or could be SSBC set up.
Brian
1986 FHP 1742
1986 WSP 2761
Old 11-04-2008, 02:29 PM
THe front are more than likely 87+ like Mikes said. The rear are probably Thunderbird turbo coupe probably swapped the whole rearend into the car. It's a pretty easy swap.
Good luck.
Old 12-25-2008, 12:12 AM
I rec'd a FAX copy of my car's CHP Assignment Card -
http://users.erols.com/hopup/chpcard1.jpg
http://users.erols.com/hopup/chpcard2.jpg
So now I have confirmed that unit number #8395 matches my VIN.
Old 12-25-2008, 12:53 AM
How did you go about to get the info?
Old 12-25-2008, 01:12 AM
Good stuff....and definitive documentation that it was a B&W.
Old 12-25-2008, 11:44 AM
PM sent...
Old 12-27-2008, 10:25 PM
Say, what's the trick to removing the bottom rear seat cushion?
Grab the bottom of the rear seat cushion with both hands. Push rearward and then pull up.
Old 04-13-2013, 01:55 PM
Decided to bump a VERY old thread -
Originally Posted by mac88chp View Post
Looks like an old crayon marking. If it was put on there by CHP Motor Transport, I'm shocked it's still visible. Temporary crayon markings like this have also been spotted written on the front plate bracket. It identified the car's assigned CHP ID# as the unit was taken from new car inventory and sent to the upfit assembly line where that number was painted on the door (always) and the corresponding license plates were attached. It might have also been applied during strip out and sale after the unit was run out.
By looking at some of the pictures from Sam's Motor Transport Picture Thread, I saw one Mustang that also had its unit number written on the side window as a run-out:
To this day, my etched numbers remain on my side window. I'm glad because I may have never learned my car's unit number otherwise.
