-   The Briefing Room (http://www.specialservicemustang.net/forums/forumdisplay.php?f=11)
-   -   CHP #E408395 is Black & White Again! (http://www.specialservicemustang.net/forums/showthread.php?t=3133)
28HopUp 01-13-2011 02:53 PM
No, I didn't take the car to the body shop -
http://mustangforums.com/forum/membe...8395insnow.jpg
The recent storm hit while my SSP was temporarily residing in the driveway. If you look in the garage, you'll see our son's '98 coupe, which is missing its rear suspension. A day-long project to swap out the 7.5" for an 8.8" with 3.90:1 gears is now going into its second week. First, we needed new spring isolators, which could not be found at the local automotive retail establishments, and Ford said it would take 6-10 days. So I bought poly isolators through American Muscle. Then we hit a common snag, where the rear bolts for the LCA's were rusted into place. After getting the first one to let go, I realized that the rubber bushings in the LCA's were cracked. So I did some research and bought a good aftermarket pair. But it turns out that these particular LCA's do not include the attachment bolts, and the correct grade 10.9 bolts are made out of a rare ingredient called 'unobtainium'. So I just bought the bolt kit directly from the maker of the LCA's. You would think that the replacement LCA's would include the hardware needed to install them!
:rolleyes:
ssp91ssp 01-13-2011 03:09 PM
Cool pic Bill !! Glad to hear you got your Control Arm issue worked out.
FHP813 01-13-2011 06:21 PM
Hey Bill, those sail panels are supposed to be white on an '85.
Andy 01-14-2011 12:30 AM
http://i56.tinypic.com/11kedtg.gif
28HopUp 01-14-2011 10:24 AM
HAHA! Thanks for the laugh Andy!!! :D
ABN2060 01-14-2011 10:36 AM
This is no help to you now but the BBK "Gripper" lower and upper control arms come with the bolts.
