-   Special Service Mustang Tech (http://www.specialservicemustang.net/forums/forumdisplay.php?f=5)
-   -   LX emblem or not? (http://www.specialservicemustang.net/forums/showthread.php?t=2715)
MOstang 05-21-2010 01:35 PM
LX emblem or not?
Hello - My 1989 Minnesota State Patrol SSP does not have the LX emblem on the driver side of the trunk lid. All the other SSP's I've owned and own (3) do have that emblem. None of the in-service pics I've ever seen of the Minnesota ones show the back end of the Mustang so no real reference there.
My questions is as follows...would it be appropriate for my SSP to have that emblem on the trunk lid? If the answer is yes, anyone have an original SSP with the LX emblem who could share the correct dimensions on location or could share a photo for reference? The emblems have been off my 93 Missouri SSP when the paint was redone so would rather go by one that hasn't had emblems off before.
Thanks for your help!
28HopUp 05-21-2010 01:41 PM
Since the correct badge isn't there, you should install one of these babies on your SSP!
http://k43.pbase.com/u12/fastgt/uplo...eptorbadge.jpg
:runaway:
NoDrama43 05-21-2010 03:22 PM
Mike the only agency that I know of that deleted the LX emblem was CHP. That is well documented. The LX emblem sits one inch from the edge of the deck lid. I will have to meausre to give you the height from the bottom lip. Will try to get to it tonight after I get home.
MOstang 05-21-2010 04:17 PM
Thanks for your help.
MOstang 05-26-2010 07:20 PM
Hi Jim - Any luck on pulling the measurment from bottom lip? Also is the 1 inch you mention from edge of deck lid...are you referring to 1 inch from the left and if so from the bottom? Just asking since the deck lid dimension on the left side is angular. Thanks for your help.
MOstang 07-20-2010 07:07 PM
Just a bump on this one to see if anyone can help with measurements on placement of the LX trunk emblem? Thank you.
CHP 3705 07-21-2010 08:13 AM
I measured several parts cars I have & mine are 1 inch from the left edge as Jim said & 3/4 inch from the bottom edge. Doug
ssp91ssp 07-21-2010 08:20 AM
Mike, I just measured the USPS LX emblem and i have to agree with Doug/Jim.:)
MOstang 07-21-2010 12:59 PM
Gentleman - Thanks for the input...it's great to have this resource. :thumbsup:
MOstang 07-27-2010 09:02 PM
Thanks again for the help...I have installed the LX emblem using dimension input from above.
