1993 Winterpark Florida SSP, 72K miles!!!
7 Attachment(s)
I am considering selling my 1993 Mustang SSP from Winterpark Florida. Those of you that have been members here for some time are familiar with my restoration through the posts and my attention to every detail. I have spared NO expense and have well over $24K invested in this vehicle with all receipts.
What is unique about this vehicle is that it has low "in service" miles, has never seen any elements (e.g.snow/salt) and is an absolute perfect, turn key SSP that is "in the wrapper". Also, the truck lid was signed by Jack Rousche!! If you are interested, please email me at beterginio@yahoo.com or call me direct at (860)919-8999. I am in no rush to sell and am looking for serious offers from buyer who can appreciate all the time and money invested. Thank you for looking and a special thanks to specialservicemustang.net! Here is the master list of what was completed: 1993 Winterpark Florida SSP (72K Miles) Restoration List Year: Agency: Unit #: Tag #: Last 6 VIN: DSO: Color code: Owner: 1993 Winter Park, FL PD 1017 147059 27-0409 WB **Vehicle trunk lid sighed by Jack Rousch!” Maintenance (All Factory Parts) •Synthetic Oil Change •Rear End Fluid Change (with limited slip additive) •Brake Fluid Flush •Power Steering Fluid Flush •Antifreeze Flush •134A A/C Charge •Spark Plugs/PCV Valve/ Air Filter/Spark Plug Wires/Fuel Filter •Distributor Cap and Rotor •ICM (Ignition Control Module) •Oxygen Sensor(s) •Serpentine Belt •Stabilizer Bar End Links and Bushings •Steering Rack Boot(s) •Coolant Overflow Bottle •130 amp alternator •Rear Shocks •Emission/Smog Pump •Factory H-Pipe •All vacuum hoses including vacuum harness •Valve Cover, Plenum and Throttle Body gasket(s) •4 Wheel Alignment and Wheel Balancing Engine Bay: (100 + Hours) •New Air Box and Fender Studs •Polished 5.0 Plenum Plate •Oil Cap •Power Steering Cap •Radiator Cap •Hood Stops Powder Coating: *Valve Covers; Plenum; Throttle Body; Mass Air Flow Sensor; A/C Compressor Bracket; Power Steering Pump; Smog Pump; Charcoal Canister; Hood Latch, Radiator, Transmission Cooler and Pulleys. Cleaning: *Underside of hood, all nuts/bolts, sheet metal, firewall etc. Undercarriage: (60 Hours) Cleaning: oUndercarriage covered in high strength all purpose cleaner and pressure washed with hot water to remove all dirt and debris. oWheels removed and cleaned and polished inside and out. oAll suspension parts sanded and coated with “POR 15” to original factory specs. oCalipers/Brake Drums/Brake Lines Painted oDriveshaft sanded and coated with” POR15”. oSway bars removed and powder coated. oExhaust wet sanded with 600 and 2000 grit sandpaper and polished to new finish. oThere is not a spec of dirt or grease on the undercarriage! Everything polished and highly detailed! Exterior: •Wet Sand entire car with 2000 grit paper •Compound then Glaze with high speed buffer to mirror finish •“Dent Wizard” (Paintless Dent Removal) removed all door dings, etc. •Apply original “Winterpark Police” decals and stripes •Front and Rear bumper covers removed from vehicle and painted •Body side moldings removed and painted •Roof holes patched and roof painted. •New “Ford” front bumper cover emblem •New Cowl Grill •New Centercap(s) •5.0 Interceptor and “LX” trunk emblems •OEM Headlamps/Marker Lamps/Parking Lamps •Satin Black Powder Coated 10-Hole Rims (including spare) Interior: •Brake Pedal •Factory OEM Floor Mats •Interior Carpet •Trunk Carpet •Interior Floor Console •Speakers •Shifter Trim Plate •Door Map Pockets •Front Seats-reupholstered •Package Tray (rear deck) •Window Tint (lightest available; exact film Winterpark PD utilized) •“Big Sky” Trunk Mounted Shot-Gun Rack Electronics: •Whelen Dash Master Deck Strobes •Whelen 75W Strobe Power Pack (upgraded from 25 watt) •Whelen “Hide Away Strobes” in taillights and side marker lights. •Whelen “Dash King” windshield mount dual strobe. •New Federal Signal PA300 Siren (upgrade from PA200) •Motorola Spectra UHF Mobile Radio and Speaker •Galls Headlight (Wig-Wag) Flasher/3x per second •4” 800mghz Trunk Antenna •Federal Signal “JetStrobe” Lightbar (10 strobes/alley lights/takedowns) •Custom bracket fabricated for Lightbar Controller replacing cassette pocket below radio. •Custom shelf for trunk mounted radio base and strobe power pack(s). Miscellaneous •Reproduction Window Sticker •California "Black" Custom Car Cover (will fit light bar and spotlight) Performance (Wanted to keep factory with hidden/tasteful performance mod’s that can be turned back to original) •B&M Transmission Shift Kit •Ford Racing Headers (non-ceramic to look exactly like factory) •3.55 rear gears (Installed by Winterpark PD) Collectables •1993 Ford ABS Police VHS Tape •1:18 Scale Mustang New York State SSP •1993 Ford Mustang Brochure •1993 Ford Mustang Police Interceptor Brochure •1993 SSP Supplement •1993 Ford Mustang SSP Order Form •1993 Ford Crown Victoria Police Interceptor Brochure •1993 Ford Taurus Police Interceptor Brochure **Winterpark PD Golf Shirt, Sweatshirt, PD Patches, Hats and Duty Vest! Attachment 1386 Attachment 1387 Attachment 1388 Attachment 1389 Attachment 1390 Attachment 1391 Attachment 1392 I have more pictures, just let me know you needs! |
Interior Pictures
4 Attachment(s)
Undercarriage Pictures
4 Attachment(s)
Engine Bay
3 Attachment(s)
Best of luck with the sale. You really did an incredible job on the car.
+1. I hope you are selling it because you have another project picked out and aren't leaving us.
They're dropping like flies!!! Good luck with the sale. BTW I can't see pics.
Awesome Car !!!
I see pictures now. Awesome car!!!:2thumbs:
Thanks!
Thanks guys, I appreciate the comments! I don't plan on EVER leaving the forum regardless if I own an SSP or not... SORRY:)! Anyway, everytime I review the list of items I completed and look at the "finished" product pictures it is certainly with mixed emotion to say the least. This is why I am in no rush. If it happens it happens, if not I have a great car.
The reasoning for the possible sale: I am looking to purchase a 1987 Buick GNX with 7K original miles: http://cgi.ebay.com/ebaymotors/Buick...1%7C240%3A1318 I plan on also selling my 1987 Grand national with 862 original miles to make room, if you know of anyone whom is interested. I will list the GN soon on Autotrader and Ebay. The Grand National should "fetch" about $45,000.00 in a good market, thus I am figuring about $42,000.00 in this market. Thats the "story" :) |
| All times are GMT -4. The time now is 12:56 AM. |
